Winch install with KFI mount
brando4905
42
6
Marion, NC
Finally got my winch installed. The KFI mount is super! I put the rocker switch right under the steering wheel. There really isn't a good place for the solenoid, so I removed the tool kit and put it in that hole. I saw a winch installed at the dealer and they put the solenoid under the middle section under seat, seemed WAY to hot an area for it. Directly over exhaust. Under the hood would have been good, but would have needed longer wires than was supplied in kit. Easiest keyed-on wire for me to tap into was the one for the 12v accessary plug under hood. Winch is Superwinch Terra 45.
Photo10 zpsb0845745
Image11 zps94150196jpe
Image10 zpsfc9abcfdjpe
Also got my hard roof on, I like it way better than the bimini.
G
GulfCoast
47
Thanks for the pics! Especially the tip on the solenoid. Now, please get it profoundly stuck, and winch it out and let us know how the mount does! :D
41,639
Been waiting for these so i can decide if i want the KFI. How about some more pics...maybe from the side?
Thanks.
Yes REAL world test!
brando4905
42
6
Marion, NC
Thanks.
Here's a few more pics at different angles.
Photo11 zpsa1c94a83
Image13 zps71f34db2jpe
Image12 zps3e87a69fjpe
bigc
bigc
421
it looks good and the terras are excellent winches go hang it up in a tree by the winch and see if the bumper tubes will handle it
41,639
Thanks. Just ordered one...
Also got an older new Champion 4500Lb winch off Ebay for $130 + $20 shipping. Now all i need is a Pioneer!
Those bumper tubes connect almost in front of the bracing behind the a-arms. I can't imagine anywhere up front that would be any stronger.
bigc
bigc
421
the tubes are very thin and are only spot welded to the frame they are pretty easy to bend the mount might suprise us and be strong enough i really dont know thats why me and bigriver mounted to the vertical frame brace tubes instead the factory honda winch mount also mounts to the vertical tubes
F
foggy
108
Will a "wide spool" winch fit on this bracket? Seems to be an advantage to pulling power with them.....and also the amount of cable. Not sure if they are worth it? I dont use a winch too often....but if you get stuck in the wild.....more is definately better. Thinking about keeping the capacity up and the price down via cable and wide spool.
41,639
The KFI page has a list of winches and bolt patterns it will mount...
Product Information
Brand new "KFI" Winch Mount for the following Honda UTV's:
2014 HONDA PIONEER 700 and 700-4
Designed to work with the following Winches:
KFI: ST17 / S2000 / A2500 / A3000 / U4500 / U4500w / SE25 / SE35 / SE45
WARN: A2000 / A2500 / U2500 / 1.5ci / 2.5ci / 2.5ce / 3.0ci / 3.0ce / 3.0s
WARN: RT15 / RT25 / RT30 / XT15 / XT25 / XT30
WARN: RT40 / XT40
WARN: Vantage 2000-4000lb
WARN: ProVantage 2500-4500lbs
RAMSEY : ATV2500 / ATV3000
SUPERWINCH : Terra25 / Terra35 / Terra 45 / LT2000 / LT2500 / LT3000
MILE MARKER : PE2.5 / PE 3.5 / VMX2.5 / PE2000 / PE3000 / PE2500 / PE3500
CYCLE COUNTRY : Work Power 1500 and 2500 / Powermax 2500 and 3500
BADLAND : 2000lb #68146
- Requires the correct Fairlead with a 4.875" Bolt Pattern (available if needed #ATV-RF)
- Listed Models come with incorrect ATV Roller Fairleads
BADLAND : 3000lb #68145 / 5000lb #68144
CHAMPION : C10013 / C10014 / C10018 / 10020 / 10024 / 12053 / 12503 / 13501(reqires rollers) / 14061
CHAMPION : 14501 / 14551 / 14552 / 40252 (4500lbs)
CHAMPION : 10028 / 10032 / 12001 / 12002 / 13001 / 20049 / 20051 / 20249 / 30045 / 30145
CHAMPION: 14001 and 14061
KEEPER CORP. TRAKKER : KT2500 / KT3000 / KT2500C / KT3000C / KT4000 / KT4000C
KEEPER CORP. TRAKKER : KT2000
- Requires purchase of a roller Fairlead (KFI #ATV-RF)
SMITTYBILT : XRC 2.0
SMITTYBILT : XRC 3.0
XGEAR: X3000 / X4000
- 4-Hole Standard (3.00" x 4.875" bolt pattern)
VENOM: 2000 / 2500 / 3000 / 3500 / 4000 / 4500 / 5000 (Hardcore Series)
- All with 3.00" x 4.875" Bolt Pattern mount-up
- All with 3.00" x 6.600" Bolt Pattern mount-up
Possibly Many others with the below standard Mounting patterns (call to confirm)
- 4-Hole (3.00" x 4.875" bolt pattern with Rollers that are 4.875" bolt pattern)
- 4-Hole WIDE (3.00" x 6.60" bolt pattern with Rollers that are 6.600" or 6.000" bolt pattern)
- 2-Hole (3.10" with Rollers that are 4.875" bolt pattern)
Specifications:
100% MADE IN USA
Constructed of 3/16" steel
Unlike all other mount competitors our mounts are metal bead blasted before they are powder coated for the best possible finish prep.
Powder coated black for supreme durability
Very easy to install
Complete installation instructions included
All mounting hardware included
Satisfaction guaranteed
Roller fairlead and winch not included
bigc
bigc
421
yes the plates will accept both the wide spool and standard spool it has holes for both the terra 4500 in the pictures is a wide spool i think the wide spools are better
brando4905
42
6
Marion, NC
My tubes have solid welds on top and bottom, sides have weep holes to let moisture out. This mount uses a wrap around "tube stiffener" piece made out of 3/16" steel where the front bolts on. And, I cant imagine any issues where it connects in the back, because the bolts go through three layers of metal (mount, bumper tube, frame receiver tube) where the bumper slides into the frame. Bigc, you may be right, it might not be strong enough, but it sure looks plenty tough to me. Most truck winches are mounted to bumpers, my Warn X8000 is attached to the bumper of my Jeep. I know thats not apples to apples, but compare the steel thickness on the two machines, then compare weight and it's all about the same.
Photo12 zpsc9f66dfb
bigc
bigc
421
you could be right it might work perfect if you unbolt the bumper and look at it closely i think you would laugh like i did how light made it is
bbdo
12
I installed my Superwich 4500 today with the KFI mount. very impressed, its a great quality piece of metal! Now I just need the plow mount and push tube and I can plow my driveway. i spliced the live wires for the remote directly to the battery so the in/out rocker and remote are active at all times. I installed the remote plug under the hood on the passenger side - there is a space there that is perfect for it.
Also did the first oil change and used Castrol 4T parth-synthetic oil plus a WIX filter. The improvement from new oil is obvious. I didn't do much riding today but up and down the driveway, I could tell right away how much smoother the engine is, and the transmission shifts. I did see some metal in the filter, but not too much.
Had a great time doing all of this! such a quality piece of machinery. I also have a Honda 928TAS snow blower that has been incredibly reliable and useful.
Reactions: Rvon
bigc
bigc
421
welcome to the site bbdo and good post about the oil
Welcome bbdo, what weight oil did you use? Have you noticed any shift differences?
bbdo
12
i used 10w-30 oil. other than being more smooth, no difference - but we are going for a long ride tomorrow and i'll report back!
I used 10-40 because of the odd amount you use in both the Pioneer and Honda Valkyrie end up totaling 7 quarts. It shifts harder and staying in gear longer when first warm but I wasn't sure if that was 10-40 or just oil without the break-in additives.
bbdo
12
i almost did 10w-40 but all of the pioneer documents specify up to 30w. i plan to keep this for a long time so, better safe than sorry. there are definitely more choices in the 10w40 though.. also considered the mobil-1 racing oil since they are essentially the same as 4T oils with the added 'bad' lube that make them track use only oils. i think either way, so long as the machine is maintained according to schedule, we will be fine.
I was just going to buy an extra quart of 10w-30 and the SAE service mechanic the dealership had said just use the 10w-40 that's what they put in everything and that's what they were going to put in it if they changed it.
