Winch installation?
Elkhunter
Elkhunter
345
453
Minnesota
If your plow you ordered is going on a P 700 I would get a 72".you have plenty of power and when you angle a 66" it would be inside your front wheel tracks.
pilsbury38
pilsbury38
47
Really? They had the 60" listed as standard so I went with 66" just for this reason.....
Elkhunter
Elkhunter
345
453
Minnesota
I have a 72 cycle country poly and feel it's just right. wouldn't want any shorter. A 66" plow angled you will lose about a foot so that will bring you at about 56" and your wheel width is 60" I think most are running 72".( Just my opinion)
TandT
TandT
357
21
Newark, Ohio
Have have the 72" Cycle Country on my P4 and run the 60" Cycle Country on my Honda Rubicon. I just odered the side panel to keep the snow from coming out over the left side. I have not plowed yet but the wife said she really liked the plow markers.
pilsbury38
pilsbury38
47
Ok got the winch all mounted and hooked up today. I cut a hole in the dash to make the switch look more factory, I came out real nice. Tomorrow I will work on getting the plow hooked up and then I won't care as much if it snows...
pilsbury38
pilsbury38
47
All done! Plow winch everything hooked up, works awesome! 8f2b35da2cef4daf936feb8cf671669e
pilsbury38
pilsbury38
47
Here's a couple pics of where I mounted my switches and stuff.....8ec9618aba2a3bae3975c086749136b51b8ddc6fe65a7bf38c95f3359feaa4ac38c97e6a1c514fb33d311648071ba696
pilsbury38
pilsbury38
47
I didn't like the idea of the solenoid being under the seat, so I used the blue and yellow wires to run to the battery instead of the red and black.
pilsbury38
pilsbury38
47
Did anyone use something for a stop to keep the cable stop from going to far up the loop of the cable?B2f6169170ce19d999567003317c8458
63,337
Are you talking so you know when to stop with the plow or just in general?
Heard of people taking a small hole, large washer, cutting a slit in it then bending it so it fits over the wire, then squeezing it back together so it want come off or even welding it together.
Personally, I hate a loose winch end bouncing around. I want the stop all the way up to the hook.
pilsbury38
pilsbury38
47
But when my stop goes all the way to the hook the loop is already in the rollers, that's what I want to stop.....
63,337
Ya, Thats where you have to do the washer mod. So it stops at the crimp where the loop connects.
They also make a different style stop that will clamp the wire wherever you want it.
This is where most people want there bump stop to be like.
vs in this location before the crimp.
pilsbury38
pilsbury38
47
Thanks, do you happen to know what they call the stop that clamps to the cable?
63,337
pilsbury38 said:
Never mind I found them thanks!
Kool.
I bet you are wanting to use it more as a plow stop.
The clamp on stops should work if you can find the right size.
Squank
Squank
I installed the SuperWinch 4500 with the KFI mount and cable stop. Not that hard to install, just time consuming because you have to figure out where to mount the components and route the cables. It also requires some dash drilling to mount the switch and/or wired remote.
Basically, you take your front bumper off, mount the winch to the mounting plate and then reinstall the bumper incorporating the winch and mount into the bottom of it. The kit comes with some replacement bolts for where they are needed. The original plan is for the solenoid to mount near the battery with a set of short red and black cables and then the winch is to connect with the longer set of blue and yellow cables. Under the seat near the battery is not a great place to mount the solenoid, so I mounted it under the hood and then used the short cables to the winch and the long cables to the battery. Worked out fine routed underneath above the skid plate with a bit of zip tying to the frame here and there.
I drilled the dash with a 1" paddle bit and mounted the wired remote plug there. I keep the remote in the glove box and plug it in when I need the winch. Didn't mount the switch at all. Works fine.
Only weird thing is the install manual for the SuperWinch says straight-up not to mount the winch inverted. The lower mount method with the KFI stuff is just that - inverted. Several folks assured me it would work fine and it seems good to go. Haven't really worked it hard yet.
The KFI winch stop is a pain to get over the end of the cable, but it can be done with a some patience and brute force. I'd suggest sitting it out in the sun for a while first if you can to soften it up a bit.
Squank
