P700 Adding Turn Signals and Light Bar
G
gsiebrecht
20
23
Iowa
I already added the light bar, next is the wiring and installation of the turn signals. I'll update this thread with a video of the turn signals when I get them installed. For now here is the light bar, switch and wiring diagram. The relay coil is wired to the accessory outlet harness, that way everything is shut off with the key, that is the only connection to the factory wiring.
It would probably have worked fine without the relay but this way it's done if I ever want to add any high current accessories. The light bar draws under 10 amps and the turn signals are like 1 amp.
20160821 184750
20160821 184803
Turn Signals
Reactions: Tflynn
Tflynn
Tflynn
Not a liberal
2,502
3,844
Northern California
Nice work, looks like your build is coming along nicely. Welcome to the club! We look forward to watching your progress!
G
gsiebrecht
20
23
Iowa
Video of the LED turn signal being tested.
Testing the operation before cleaning up the wires and connections
20160824 181642
The electronic flasher
20160824 184308
Reactions: Tflynn
