BOX1
P700 Afr plus by dobeck
motorman18
439
277
Laurel, MS
Is anyone running a afr+ By dobeck how does it perform is it worth the money
motorman18
439
277
Laurel, MS
Well i have not seen that till now that was bad to the bone wish he had some big tires with aggressive grip and in deep mud that were u really see what one can do. He sure ran up in speed quickly but alot of work and going into a brand new bikes engine I hope don't see inside of mine for long time
Tflynn
Tflynn
Not a liberal
2,502
3,844
Northern California
I did some more digging on AFR+ and it looks to be the ideal solution for us 2014 model owners that occasionally go into the high altitude. I emailed Dobeck to confirm that the AFR+ is a complete solution and indeed it is, no additional parts are necessary.
motorman18
439
277
Laurel, MS
They say that it would just help on high altitude i live in south Mississippi was wondering if it would help with it running so lean i also have it snorkled so its even leaner then stock
Tflynn
Tflynn
Not a liberal
2,502
3,844
Northern California
Should help with either. When you set the desired AFR it will just keep it there whether that means overcoming a lean condition or a rich condition. If you're never going to high altitude then one of their EJK's would likely do you fine. The EJK just adds more fuel at different parts of the power curve.
d_b
d_b
302
240
Just a heads up. Always think of the future..are you going to change anything later ? I have one and absolutely love it. Have changed multiple times.
Tflynn
Tflynn
Not a liberal
2,502
3,844
Northern California
You have which one?
motorman18
439
277
Laurel, MS
Mines a 14 model don't have o2 sensor willt the afr with the sensor work on mine i no will have to weld on the exhaust
Tflynn
Tflynn
Not a liberal
2,502
3,844
Northern California
Yes for the 2014 you'll be fine you just have to weld a threaded bung to the header in order to install the O2 sensor
d_b
d_b
302
240
So you would recommend it then? Damn @d_b you may have just cost me $400!!
In my case I recommend, However I've keep changing set ups. This winter I will be going turbo with the gears and 32 so once again I'll need to change. Plus even stock you can change settings on the fly.
motorman18
439
277
Laurel, MS
When u say gears u mean portals correct and r u building the turbo set up or is someone selling a kit
d_b
d_b
302
240
yes, portals.No kit as of yet, there may be soon enough. Yes we built a set up. I'll put pics under my build.
BOX2
box3
