BOX1
P700 Another lift thread
Gator
Gator
The Most Unknown Member
2,468
10,325
Louisiana
I'm looking at lifts and I'd like someone that has one to weigh in.
How high have you lifted yours?
Who's lift kit did you use?
Is 3" too high? (will it break axles or tear boots?)
If you made your own, do you have a drawing?
Some lifts are straight up while some (simpler) are inward. Does it really matter?
39,078
DONT GET THE HIGH LIFTER ADJUSTABLE LIFT!!
I've got a thread about it with pics somewhere but can't find it.
I'll keep looking
39,078
I can also provide you with some info on a custom lift for the front with fox shocks
Gator
Gator
2,468
10,325
Louisiana
I like your upper bracket.
What is the basic problem with the highlifter?
39,078
It puts too much leverage on the upper shock mount. It will bend it and tear it from the frame.
0ec1589b34f273927d6dd85899c26eb1
39,078
More info on the rzr shocks here if you have read it already. Specific info about the bracket starting on post 50.
Tflynn
Tflynn
Not a liberal
2,502
3,844
Northern California
The lifts that move the bottom of the shock in toward the center of the vehicle will in effect soften the ride because it gives the wheel slightly more leverage on the shock. It's not a huge deal BUT if you are already thinking your suspension is too soft it's something to consider.
39,078
Some say I ride hard, I really don't think so. Either way you look at it, HL is a flawed design if used on the 3" setting. Some people may not have trouble YET. I say that because I too was warned about the HL and told people the same thing you are telling me now. I thought I was good as I had been beating my pioneer with out failure. It just took a little more time.
Gator
Gator
2,468
10,325
Louisiana
I am convinced. The HL has a long moment arm by design. Putting the lift down on the A-arm (like your design) is better.
d_b
d_b
302
240
Why buy a lift, if your going to replace your shocks. Just get suspension lift with better travel.
Reactions: green02crew
HondaPower
39
32
Mines a 2-3 but for the life of me can't remeber the name. It came out the first month the 700 was released.
20160122 163819
rockfeller
rockfeller
9
Fl
I have a 2" lift with 28 and have broke right front 3 times.
swsebek
swsebek
2,854
5,828
pa
Is what I believe as well.Totally
swsebek
swsebek
2,854
5,828
pa
BOX2
box3
