P700 Anybody installed the EZ steer power steering kit
SD1976
SD1976
23
Anybody installed the EZ steer power steering kit on the 700? Pro's ? Con's?
It's awesome!
2nd accessory I should've added after a winch. Takes about 45-60 mins to install.
319,218
We did and loved it! Worked very good especially in 4lock. Big difference really. What was the big deal is that we put it in at the same time as the big tires and you still absolutely knew it was there. I may not say it's a must if on roads at speed but wheeling around in 4by on technical stuff or going to bigger tires absolutely! Pretty straight forward to install except you have to cut a little of the floor ahead of driver feet but not a biggie.
SD1976
SD1976
23
Ok thanks for the response Ill be ordering a kit soon!
319,218
Absolutely. I'm sure you'll enjoy it!
bobbyhill
bobbyhill
Junior Moderator
1,271
952
Smithfield, VA
@SD1976 do you have a heater or plan on it? they require the same space for install but if you call SuperATV they will make you a longer harness so can mount things in a different location to fit both!
Reactions: CumminsPusher
SD1976
SD1976
23
I sure don't Bobbyhill but thanks for asking!!
SD1976
SD1976
23
Will the stock little battery work with this power steering kit and my Warn 4500 winch?? Isn't there a upgrade to install a bigger battery under the driver seat??
hydrantman
I installed it and what a difference especially in Diff Lock, also installed a yellow top battery under the driver seat, glad for both updates!
SD1976
SD1976
23
But wasn't there a kit someone was offering to install a full size battery under the driver seat??
SD1976
SD1976
23
Ok tks Ohanacreek! I'll be looking for it!!
39,079
Power steering is worth it! Power steering and fender flares are tied for the best two mods I've done. I've got over 600 miles and haven't been in a situation where I needed my winch. I've never used it to extract myself but I've used it for utility things. A close third would probably be 28" tires and then Fox shocks.
Joe
319,218
I loved the flare kit too but I was ripping the front ones off all the time :-(
spifyd
spifyd
420
178
newhampshire
power steering and heater will fit you just need to make a new mount for the steering control
Reactions: ohanacreek
allgm1
allgm1
1,049
1,484
New Hampshire
Glad to hear the two will coexist I ordered my power steering yesterday (it'll be here tomorrow) it will be in before the weekend
