P700 Anybody installed the EZ steer power steering kit
SD1976
SD1976
23
Glad to hear the two will coexist I ordered my power steering yesterday (it'll be here tomorrow) it will be in before the weekend
Oh good deal let me know how you like it!
66,043
Wheres the best place to buy this and I take it works as a steering damper also.
4drakes
4drakes
7
Yes I have installed power steering to my 700.Its makes all the difference its a must for long rides
63,337
Road one with it installed, it was nice and did dampen the kickback.
Really, you dont think you need it until you ride one with it.
He got his from here - http://amzn.to/1ltVI2Q
39,079
For me the biggest improvement IS the steering dampener. Sure it makes steering easier but it's not that bad while rolling, but the dampening effect is great.
Joe
Reactions: Plumber32
allgm1
allgm1
1,049
1,484
New Hampshire
the most inexpensive place you can buy them is on ebay , I called superatv themselves, I don't like to deal with the middle man if anything should happen. The folks that work there are all very helpful, I called them and told them I saw one on fleabay $540 and they took $40 off their price of $600 for me, I paid $560 straight from them, still better than $600 a little extra money is worth the piece of mind for me. Its supposed to rain here tomorrow, dam I might have to sqeeze the pioneer in the garage and get busy
Gator
Gator
The Most Unknown Member
2,474
10,370
Louisiana
For you guys that have installed them.
How long does it take, and what was your biggest issue (what took the longest)?
66,043
Well I just ordered it ! Going to wish I had it Friday 8+ inches of snow here in southern wisconsin!
Reactions: SD1976
allgm1
allgm1
1,049
1,484
New Hampshire
from what I've read the biggest problem is the instructions that come with it. Apparently fedx had a brain fart yesterday were unable to deliver mine yesterday so I'm hoping it will show today as I have no work going on today. If I get to put it in I'll get some pics.
allgm1
allgm1
1,049
1,484
New Hampshire
allgm1
allgm1
1,049
1,484
New Hampshire
OOps, didn't get any pics, but its in. If anyone is on the fence about power steering, by all means do it, preferably before you install your heater. As Noted by others, the instructions really are straight forward for the most part,except there is no mention of the heat deflector that has to be removed and trimmed in 2 places. First it needs to be cut to go around the mount bracket for the power steering, and the around a u joint on the lower steering shaft. Pretty much makes driving the pioneer like driving your car, I only drove it around the yard for a few minutes after the intall, but I plan on a little riding tomorrow on some boney arse trails so I'll see how it works then.
Reactions: ohanacreek
Tflynn
Tflynn
Not a liberal
2,502
3,844
Northern California
This is on my Christmas list for sure. For those that have had it installed for awhile, how would you rate the durability/reliability of the unit? Any problems come up?
hydrantman
Have had mine on since June no problems at all. Your also not limited to how you install the control box my buddy and I installed my control box standing up to give me more room. You will a BIG difference in 4 wheel dif lock mode.
allgm1
allgm1
1,049
1,484
New Hampshire
I drove down the trail today in 4-loc for a while with the power steering its just like driving in 2 wd.
Reactions: Tflynn
39,079
I haven't been exactly easy on my Pioneer and the power steering has never failed. After almost a year of abuse I would still recommend it.
allgm1
allgm1
1,049
1,484
New Hampshire
I had to relocate mine also, the heater needed to go where they want you to put the control box, I just made a mounting plate and drilled/ tapped the frame to mount it, I'm running out of room under the hood
20151121 135737 zpsqi4keisj
ez steer control box tucked in behind the winch contactor
20151121 135730 zpse3zgopqj
Reactions: Hardwaterflyer
I had something similar although after the third rewire(to add capacity and circuits) mine was a lot less clean. I did try NOT to drill anytime any frame members to reduce the amount of rust over time.
74e57bef4ba057109b038e5aacf10059
66,043
Mine came in yesterday. What do you know, no instructions, I was able to download them though. Heat in the garage is cranked, going to start about noon , and get er done!
