BOX1
Arched A-Arms pioneer 700
scott
scott
1,212
1,354
lyman, South Carolina
Guy in the Facebook group is making forward arched a-arms. Just sharing with yall. Still a work in progress. I think he is going to sell them too. He is going to do the rears also.
62,641
Look at that boot. Looks like it is about to pull apart.
Well... to each, his own.. I guess.
Will look bad A when finished... but better go ahead and buy all 4 axles.
scott
scott
1,212
1,354
That's a lot of work and changing a lot. I will be very interested to see how it rides and how well it holds up. If i was going to do something like this i would just arch the lower A-Arm that's all.
39,078
If I were doing new A-arms, I would arch them for 2" lift and extend the track width by 2" per side and move the front wheels 2" forward.
I'm running 28" tires and they rub with my high lifter set on the 3" setting. In also running 3.5/3.5 wheels with 1" spacers. That widened track width increases the scrub radius which causes more effort to turn the steering wheel and caused he front tires to move back into the fender when turning sharp.
A guy can dream can't he?
Reactions: ohanacreek
scott
scott
1,212
1,354
They are forward arched 2" and lifted 3". I was thinking last night i would also extend them and use longer travel shocks but then that's even more work. Would have to change axles and buy new shocks and springs. He is also making just lower A-Arm arched which that is something i might would buy.
39,078
I would be interested in doing some one day, wether making them or buying them.
The guys that weld on oil rigs are GREAT welders, sometimes better than the robots, but being as you could cause serious injury if a weld failed, IE 40mph and the left front collapsed, I would be wary of buying something like that from an individual.
Reactions: joeymt33
W
Westtnpioneer
Edjumacated
350
603
West Tennessee
A robot can't see porosity and make adjustments. I would take a human welder any day.
For certain methods of welding a human just can't possibly do them. But yes a quality welder out does a robot.
scott
scott
1,212
1,354
Looks good I think. Am surprised the axles don't look in a bind either. He welded the shock tabs higher up on A-arm to give it a stock style lift no brackets. I like it. Not going to buy it though. I might buy the front lower A-arm just arched and the rears lower A-arm arched.
BOX2
box3
