Best Rear View Mirror Options, No Shaking.
T
tractordr
Hi All - Just wondering if anyone can make a recommendation on a rear view mirror for my new Pioneer 700-2? My main concern is how they can shake and make the image nearly impossible to see. I have a side rear view mirror on my Rancher and it can be very difficult to see from engine and trail/road vibration, is this an issue on the Pioneer as well? Is there a rubber isolator that can be inserted under the mount to reduce the vibration? Thanks in advance! TD
allgm1
allgm1
1,049
1,484
New Hampshire
I have koplin side mirrors on mine they don't shake, I don't have a mirror in the middle yet so I can't help you there. The koplins are made for a 1 3/4" tube so you need to put a peice of inner tube around the roll bar before installing them.
My only complain is the Kolpins can get pinched between the rops and a tree and then the mirror will break, the seizmiks while more expensive have a different design that pushes the mirror past the bar when it's pushed in.
T
tractordr
Thanks for the replies. I need to see what's available on the market I noticed Amazon.com sells em for $15-$20.
