Commander XT shocks
Gator
Gator
The Most Unknown Member
2,471
10,350
Louisiana
Are those the same shocks that come off the 800?
I'm gonna buy them if they will go on my machine.
Tramguage1
Tramguage1
Texan
7,119
26,930
Somereset, Texas
Yes I think the 800 is the same. From what I have been told on here, they will fit the pioneer 700 with very minor modification to the rear lower eyelet
Sent from my SAMSUNG-SM-N910A using Tapatalk
Vato
Vato
180
159
You will need to change out both rear shocks upper and lower bushings and sleeves.
Tramguage1
Tramguage1
Texan
7,119
26,930
Somereset, Texas
I have been talking with Sundayrider, I think I'm going to replace all the bushings with new polyurethane bushings. I will see when I receive the shocks.
Tramguage1
Tramguage1
Texan
7,119
26,930
Somereset, Texas
@Texguy02, the Commander shocks give a far superior ride quality when used on the 700-4. Also help with bottoming out the supention with the factory shocks that occur when hitting dips when running down the trail.
spifyd
spifyd
420
178
newhampshire
I have fox and have used the stock one when I got it. I road a unit with just the fronts changed. I was shocked how good they were. no pun intended. I beleave the commander shock are as good as the fox shocks on the 700. if I didn't have fox already I would be searching very hard for some commander shocks.
Reactions: Tramguage1
Tramguage1
Tramguage1
Texan
7,119
26,930
Somereset, Texas
Look what the brown truck brought today!
Reactions: joeymt33 and Tflynn
Tramguage1
Tramguage1
Texan
7,119
26,930
Somereset, Texas
The bushings look a little worn, going to try and replace all the bushings before installing them.
I'll take some pictures along the way.
Mike
Tflynn
Tflynn
Not a liberal
2,502
3,844
Northern California
That's awesome @Tramguage1! Good luck with the install. Replacing bushings is a good idea. I think you'll really enjoy the ride!!
Gator
Gator
2,471
10,350
Louisiana
Cool. I bought the ones that you opened this thread with. They are scheduled for delivery by the end of day today.
I'm out of town so hopefully this weekend I can start the conversion.
Tramguage1
Tramguage1
Texan
7,119
26,930
Somereset, Texas
Cool! I haven't had time to mess with them yet. I need to order all new bushings for front and back, waiting on the tubing for rears and then need to order tubing for front.
1 of these has a oily residue on it, not sure if it's leaking or from somewhere else. Hopefully it's not a bad shock! If so guess I'll order just the shocks through eBay for $150 bucks and swap them out.
Tramguage1
Tramguage1
Texan
7,119
26,930
Somereset, Texas
There is a least 1 more set on the commander fourm for sale. Anyone else want them now is a good time
Just make sure you are not bidding against others on this fourm!!
Tramguage1
Tramguage1
Texan
7,119
26,930
Somereset, Texas
OK guys I couldn't take it any longer!!!!!!
I installed the front shocks. Made sure I had the 4 best bushing installed in the front shocks. It's SUPER EASY to do. Only need 2 14 mm wrenchs, a small lineup punch , small hammer and a jack to lift the front end. (With emergency brake set) sorry P1k guys!
Tramguage1
Tramguage1
Texan
7,119
26,930
Somereset, Texas
Wow!!!!# what a difference it makes.
And added about 2 inches of ground clearance. I took pics as I went so I'll see if @Hondasxs would lIke me to do a rightup.
If anyone has any questions let me know.
Darn I better get on ordering those new bushingsite for the rear!!!!!!!
d_b
d_b
302
240
I've already done this with mods, but would love to see a write up. All credit has to go to @green02crew
Reactions: green02crew
Tramguage1
Tramguage1
Texan
7,119
26,930
Somereset, Texas
That is true. I will just add my step by step pictures and I agree @green02crew should get all the credit for this fantastic mod.
Brentc
Brentc
71
67
SE AK
Just wondering if anybody has been able to do a side by side ride comparison with the fox's to the commanders? My friend has the fox's and they are a night and day difference.
Reactions: CumminsPusher
