P500 Deer Hauler
Spellmajr
Spellmajr
375
1,143
North MS
Picked this little dude up at academy for 54$. Should be easier to slide a deer on that than lift him up all the way to the rack. Especially when I'm riding solo.
Spellmajr
Spellmajr
375
1,143
North MS
Ran into a problem. Took it for test run and that thing bottoms out quick when crossing creeks or steep incline
HUCK
HUCK
1,047
2,314
ARIZONA
Hmmm , with the deer size you get I would think a roof rack would be ok . roflmao
Reactions: JTW
HUCK
HUCK
1,047
2,314
ARIZONA
At least I don't need my wife to load it for me like you do![/QUOTE
Only way I would load a deer is if it needed a lift . :D
Reactions: JTW
solrus
solrus
1,629
2,511
Montana
I just use hitch adapter to accommodate 2"
Sent from my XT1585 using Tapatalk
solrus
solrus
1,629
2,511
Montana
Reactions: JTW
DaddyDubbs
DaddyDubbs
13,714
128,070
I use a gambrel and pulley hoist system and field dress vertically against a tree (keeps everything cleaner).
Have a line attached to top block, throw line over a limb on a tree, pull block up to limb, tie off around tree, attach lifting end to deer antlers (or neck if doe), Raise deer to vertical position.
When finished simply lift hind legs and set on back rack as you let out slack on the pulley system, easy 1 person solution, even easier with a helper.
Deer
Reactions: solrus and rocmar
154,391
Had a buddy that insisted on doing vertical dress. We gutted a few deer together and he hit the sh** sack every time. I can handle some pretty heavy stink and that one would gag a billy goat. Definitely cleaner and easier if done correctly though. ;)
