P700 EMP Roof on 700-4
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
Does anyone have the EMP roof, and more specifically on the 700-4?
I like their products. im planning on getting a roof for just the front of my 700-4. Debating on this or the Honda one.
Pioneer 700 Aluminum Top
Gator
Gator
The Most Unknown Member
2,474
10,376
Louisiana
I like the way that looks, and it is a few inches shorter than the Honda Roof.
scott
scott
1,212
1,354
lyman, South Carolina
Guy on Facebook makes a metal 700-4 roof. It's really low profile. You can get it for just the front also. It comes apart so you can run it as a full 700-4 roof or just the front section. 3c1b65080be92e679a3a30c5ee890c2913329253409b43835e5e53248866a12a
Reactions: LandPioneer
tjoreo
tjoreo
1,010
1,929
Southern Idaho
I was looking at my 700-4 the other day and thought about you. I don't know if factory front (2p) top is much lower then the full (4p) top. Looking at your pictures of the lack of head room getting in your garage it looks a little tight for any of the factory tops. They sit a couple of inches higher then even the top roll bar.
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
well if thats true then i might be forced into a EMP if it fits
My garage is 7' tall, but the door doesnt go all the way so im also looking at being able to attach a hook to the door and pull it all the way up.
tjoreo
tjoreo
1,010
1,929
Southern Idaho
I have the 4p roof so I can't speak for the shorter roof, but I would assume it would sit higher then the back bar. I will take a measurement at the top of the mid bar and let you know.
Reactions: Dragon21
tjoreo
tjoreo
1,010
1,929
Southern Idaho
I measured my roof and at the mid bar it is 81" tall. There might be a couple of inches to work with but I just wanted to make sure before you get something that won't work. My 700-4 is stock other then 26 inch tires. Good luck.
Reactions: Dragon21
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
Thanks! is that the same as the rear height?
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
might just be an illusion, but looking at the pictures the middle looks higher than the back with the roof on it. 81" with 26 tires i could live with. I would probably get 26" tires myself. leaves 3" left over to squeeze in as long as i hold the door open all the way.
I appreciate you taking the time to check on that!
tjoreo
tjoreo
1,010
1,929
Southern Idaho
I actually measured it too and I don't think it is an illusion. According to my measurements it is higher in the middle, but the ground where I have it parked is just gravel so I can't say how level it was. Hopefully it will work for you. They are very nice roofs, plenty strong (I can stand on it), and allows a perfect fit for the factory windshield. I just don't know why they raised it so much over the already tall roll cage? If I can help more let me know.
Reactions: Dragon21
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
thanks, if there is no advantage in height with doing just the cab im sure i will end up with the whole roof. Im only doing the EMP half windshield though.
tjoreo
tjoreo
1,010
1,929
Southern Idaho
That sounds like a good setup to me. One other accessory you might want to look at is either the mid or rear panel. I know with my full windshield and roof it sucked alot of dust into the rig and after a couple of minutes the kids would be filthy in the back. I have the rear panel for the summer and the mid panel for the winter when they are not riding with me. I don't know if the half windshield will have the same problem but just something else you might want to look at. Let us know how it works out.
