P500 front shock package
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
Ok cool let me know roughly how much you were saying in a earlier post 1hr to do fronts how long to do rears can we do it in one day ?
yes definitely 1 day if you have you bed off before you come up will save time amd let me work the numbers for you
Reactions: miano248
miano248
miano248
370
398
oceanside long island new york
ya definitely ill take the bed off before I come up cause I viewed the pictures and see were the upper part of the shock mounts to and that angle the rear shocks are mounted works well better then factory ? is the stock mount for the rear shock on control arm still factory location ?
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
the lower is stock location and it is night and day difference they feel the same a the factory fox shock on the wildcat trails
Chooglin
Ok let's see what he wants to do and we shall go from there I'd like to see so pictures of rear mod and why are you getting rid of them ????
I set mine up a little different than the rest of the guys that have done this.
Reactions: jak9922
miano248
miano248
370
398
well ive never test rode a wild cat trail cause not a popular machine around here only Hondas and the rubber band transmission utvs what they call piglaris
Chooglin
maybe ill see ya there cause the wife and I were thinking of that weekend also you getting a cabin or staying in one of the towns ?
We will be getting a cabin at Ashland resort or at Hawks Cabins , not sure wich one yet !
Reactions: jak9922
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
pretty much equal to any nonpiggy back facory fox shock
Reactions: miano248
miano248
miano248
370
398
IMG 2367
Are these the shocks your talking about ?
Reactions: jak9922
chrisC
chrisC
138
259
Newfoundland, Canada
I have the same shock setup and it is great!
On slow rockcrawling trails you'll find that you are no longer bouncing off the seat ! The suspension actually works! My riding friends comment that the rops aren't swinging back and forth going up the rough trails....They can see the suspension doing its job. The tires stay planted like they should...Which helps with the open front end we have.
I use my friends Trail 700 limited occasionally.It has the Fox (non-piggyback).I don't know about being as good a ride....But it is light years better than stock.
You Will be impressed when you take Jak's for a spin!
Sent from my SM-N910W8 using Tapatalk
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
the trail has more travel but i think the compression and rebound feel about equal
Reactions: Dp5hunter
