P700 LED light bar install
Tflynn
Tflynn
Not a liberal
2,502
3,844
Northern California
I picked up a 6" light bar at Cabelas yesterday and I thought I'd walk through the install for anyone that isn't familiar with how it's done.
Tflynn
Tflynn
Not a liberal
2,502
3,844
Northern California
First thing was to mark where the switch will go on my switch plate.
Tflynn
Tflynn
Not a liberal
2,502
3,844
Northern California
Next I decided where to mount the light. It just so happened that the mounting holes for my winch lined up perfectly withe the holes on the light so I decided that was as good a place as any!
Tflynn
Tflynn
Not a liberal
2,502
3,844
Northern California
Now for the wiring. The light simply plugs in to the harness, only fits one way so you can't mess it up
Tflynn
Tflynn
Not a liberal
2,502
3,844
Northern California
The power supply is just as easy. Red wire to the positive terminal and black wire to negative.
Tflynn
Tflynn
Not a liberal
2,502
3,844
Northern California
This picture sucks but it is just showing the wires to the switch. It doesn't matter which wire goes on which terminal so once again you can't mess it up
265,207
Looks good, that appears to be a bright little bugger.
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
Nice pics bro looks good in that spot :) just a tip go with a squared switch on the dash to keep everything uniformed ;) end result ull be happier looking at it
Tflynn
Tflynn
Not a liberal
2,502
3,844
Northern California
Tonight I'll see just how bright it really is. But we all know how installing lights goes, once you get one on there you gotta have another...and another! I'm already thinking I want some cubes up high and perimeter lighting for those times when work goes on after dark (usually that's discovering a hole in the fence at sundown!) plus maybe a bigger light bar in addition to this one.
Reactions: Eltobgi
39,079
Thanks for showing this. I've been considering a flood light and you've shown me a good place for it.
BTW, those tires still look great!
Joe
Reactions: Tflynn
Tflynn
Tflynn
Not a liberal
2,502
3,844
Northern California
Thanks @joeymt33, in an hour or so it should be dark enough to test it out and see how much it helps. I'm curious as to how much the 6" bar will even help, I'll attempt to get pictures
Tflynn
Tflynn
Not a liberal
2,502
3,844
Northern California
I agree. Eventually I'll get all uniform switches when I decide what all I'll have on there. I'm thinking front winch, rear winch, perimeter lights and front lights. Maybe mount a spare switch just in case!
HappyHonda
HappyHonda
50
34
looks awesome!! @Tflynn and great write up, I'm probably adding an LED or 2 over the winter and I don't have a lot of electrical experience so this will (and already has) come in handy!
Tflynn
Tflynn
Not a liberal
2,502
3,844
Northern California
Glad to be of some help! And just a word to the wise, I'm already considering upgrading that 6" to a 12" or more. I knew this would happen!
265,207
Haha Grasshoppa...
I started with this.
F9b41f725feed7465d10b999241f63da
Then...
55ae6fccdb280f02bab872a163e5c9a1
This is what I sold it with
C1e3de4350e54bc3e855d664c57a8515
Love the last pic, I got trolled in another thread tonight about too bright of lights because I had one light bar. :p
