P1000 light bar questions
JimH1
JimH1
59
102
Duluth MN
I just mounted a 42" light bar on my rig it is 240 watts and when I do the math it looks as if I need a 20 amp fuse. I have the Honda accessory fuse block that has the socket for the light but it is 15A .
I want to run the light from my Honda switch panel, can I buy an after market switch and connectors to make this work?
Reactions: dotman1
265,161
Yes you can buy aftermarket. What you need is a rocker switch , a 35-40 amp relay, 20 amp fuse. You can have power come into the rocker switch from OEM 15amp source, then out to the relay. The relay can be wired direct to battery with 20amp fuse, then relay, then out to light. When you turn on switch the low amp OEM power source closes the relay to pull high amp power from battery to light up the light. There are many cheap kits on Amazon.com that have what you need. Like this:
https://www.amazon.com/gp/aw/d/B00SAAW8Y8/?tag=sxsweb24-20
JimH1
JimH1
59
102
Duluth MN
Thanks for the input. Cant wait to light up the night!
well I bought the fancy wiring harness with the rocker switch. It was a piece of cake to hook up. Thanks everyone for the help. I can't believe how it lights up the night.
Unnamed
