1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Pioneer 700-4 Vs Yamaha Viking.
Discussion in 'General Pioneer 700 Discussion' started by Hondasxs, Jul 18, 2013.
  1. Hondasxs
    Hondasxs Administrator
    Staff Member Moderator Life Time Member
    5,271
    1,614
    Comparison between the Pioneer 700-4 and the Yamaha Viking.
      2014 Pioneer 700-4 2014 Yamaha Viking
    SxS
    2014 Pioneer 700-4
    MSRP: 11,699
    2014 Yamaha Viking
    MSRP: 12,699
    ENGINE
    Engine Type
    675cc liquid-cooled
    OHV
    single-cylinder four-stroke
    686cc liquid-cooled
    SOHV 4 valve
    Bore And Stroke 102.0mm x 82.6mm 102.0mm x 84.0mm
    Compression Ratio 9.2:1 10.0:1
    Induction Fuel Injection (PGM-FI), 40mm throttle body Fuel Injection (YFI)
    Ignition Full-transistorized with electronic advance Transistorized
    Starter Electric Electric
    DRIVE TRAIN
    Clutch Automatic Automatic
    Transmission Automotive-style with hydraulic torque converter, three forward gears and Reverse. Yamaha Ultramatic V-belt with all-wheel engine braking; L, H, N, R
    Drive Train 2WD,4WD, locked 4WD, shaft drive Yamaha On-Command; 3-way locking differential; 2WD, 4WD, locked 4WD; shaft drive
    CHASSIS / SUSPENSION / BRAKES
    Front Suspension Independent double-wishbone; 7.9 inches travel Independent double-wishbone; 8.1 inches travel
    Rear Suspension Independent double-wishbone; 9.1 inches travel Independent double-wishbone; 8.1 inches travel
    Front Brake 200mm hydraulic disc Dual hydraulic disc
    Rear Brake 170mm hydraulic disc Dual hydraulic disc
    Front Tires 25 x 8-12 25 x 8-12
    Rear Tires 25 x 10-12 25 x 10-12
    DIMENSIONS
    Length 114.8 inches 122 inches
    Width 61.1 inches 61.8 inches
    Height 78.3 inches 74.1 inches
    Wheelbase 76.8 inches 84.1 inches
    Bed Length Inside Not Listed Not Listed
    Bed Width Inside Not Listed Not Listed
    Bed Capacity 1000 pounds 600 pounds
    Towing Capacity 1500 pounds 1500 pounds
    Ground Clearance 10.3 inches 11.8 inches
    Turning Radius 14.8 feet 14.8 feet
    Weight 1396 pounds - Includes all standard equipment, required fluids and full tank of fuel?ready to ride. Net Weight: 1342
    Unknown if dry or RTR
    Maximum Weight Capacity Not Listed Not Listed
    GVWR Not Listed Not Listed
    Fuel Capacity 8.2 total gallons, including 1.2-gallon reserve 9.7 total gallons
    OTHER
    Available Colors Red, Olive, Honda Phantom Camo™ Red, Blue, Green, Realtree
    Model Id SXS700M4
    FACTORY WARRANTY INFORMATION
    Duration One Year One Year
    Description
    1 Year Transferable limited warranty; extended coverage available with a Honda Protection Plan
    6 month limited factory warranty, extended coverage available
    Tags:
  2. Hondasxs
    5,271
    1,614
    Why would anyone pay $1000 more for a Rubber band driven sxs?
    Now of course there are a few YouTube video's comparing the Viking to the Gator and even the Ranger 900... But Hum.. I wonder who produced those video's.
  3. greenatv
    greenatv New Member
    Life Time Member
    Feb 18, 2013
    128
    hahhahaa... so the Viking is called a 3 seat with only 8 inches wider then the Pioneer? That tells me that the Pioneer might could be altered or arranged to seat 3 people in the front seat. especially if they are younger.
    what you think
  4. slowdryrider
    slowdryrider Member
    Life Time Member
    Jul 14, 2013
    344
    10
    Was never a big fan of the Yamaha Rhino.My cousin has one with the 660 motor its a 07 model. he's got bucket seats with the engine cowling between the seats.Its really noisy and lots of heat comes from the cowling. the heat part is nice in the winter but with a full cab its loud.He was looking at getting a Viking because of the 3 seat capacity.The motor is under the bed now like the Polaris Ranger 900. Supposed to be a lot quieter in the cabin.I suppose its up to the individual what they prefer I like the looks of the Honda Pioneer now way better the the Big Red .
  5. greenatv
    greenatv New Member
    Life Time Member
    Feb 18, 2013
    128
    Your right about that. The BR was just ugly.
    Looking at the specs between the Pioneer and Viking there is not really that much difference.
Share This Page
sssssss
Loading...
