BOX1
Plow
Jerry3
Jerry3
121
Arkville, NY
What are the pros and cons of the front mounted plow vs the mid mounted plow? The one that warn made for the pioneer that is available is the front mount, but I was kind of thinking a mid mount would be more rugged... Thoughts??
RacerX400600
RacerX400600
32
6
If you take it off and put it on a lot the front mount is really nice with easy access to the mounting pins.
Jerry3
Jerry3
121
Arkville, NY
yes that I am aware of, I only plan on putting it on once in the fall and off in the spring
Jerry3
Jerry3
121
Arkville, NY
Anyone have any new thoughts on the durability of the front mount plow vs the mid mount? I'm trying to see if its worth waiting until an aftermarket company makes the midmount option...
Jerry3
Jerry3
121
Arkville, NY
Still waiting for an aftermarket company to make a mid mount plow, as I feel it is more rugged, has anyone had any bad luck with front mounted plows? I am starting to worry that the snow will be here before the mid mount plows...
brando4905
42
6
Marion, NC
I could be wrong, but since the front mounts came out several years ago, and they are SO much easier to connect, I doubt they will be making a mid mount for the Pioneer. If your springs are set up right on the plow, you shouldn't have any issues with the front mount.
Jerry3
Jerry3
121
Arkville, NY
My dealer called to say Moose finally made the belly mount for the plow, and it will be in the end of the week, along with the KFI winch mount and a 4500 superwinch, and if I'm lucky my doors too. I am thinking about ordering the power angle kit for the Moose.
BOX2
box3
