BOX1
P700m4 RZR Shocks??
bagotaco
bagotaco
121
77
It took me about 3 hours to design and fab up these 2 brackets and $300 for the shocks. I have more time than money so I'm not spending a grand lol
Reactions: 500oneer and scott
TimmyBoy84
TimmyBoy84
56
34
Southern California
My buddy has a Rzr 800S with the fox podiums, maybe I can get him to take a couple off for a test fit :), then convince him to buy new ones and sell me his lol.
Reactions: Tflynn
TimmyBoy84
TimmyBoy84
56
34
Southern California
Took the wifey and some friends for a long and bumpy ride over the weekend and after 5 hours of woops, gnarly rock crawling hills that claimed some quads lol, numerous bottoming outs and a couple back seat bobble heads i think i convinced her to let me buy some new shocks!!! :D:D:D Got the "OK" today to pull the trigger :D! Just in time before our thankgiving trip :). Haha i knew it would work too!
264,675
@TimmyBoy84 Working it like a BOSS! Well played sir. ;)
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
damn lucky you the last time I took wifey out riding she got pregnant lmao o_O
39,078
Did you make the brackets because the shocks were too long?
39,078
So you raised the upper shock mount and these shocks still gave you lift?
bagotaco
bagotaco
121
77
Yep. Raises it 2" and with the adjustable coils I could get another inch if I wanted. I'm running 28" Zillas without rubbing
Reactions: joeymt33
39,078
So the 19-3/4" shocks would also give lift if a bracket wasn't used. It would be nice if I could get a set to install with out making a bracket and it would allow me to remove my trashy HL lift.
Joe
bagotaco
bagotaco
121
77
Joe
The 19" ones will be a direct bolt on. I don't think it will lift it tho. I have the front superatv lift I'll sell you.
39,078
I'd like to do the same thing you've done and remove the lift brackets. My HighLifter adjustable lift is causing major problems so I may do what you did.
I really appreciate your help so far.
Reactions: bagotaco
39,078
I had someone measure a 2015 RZR 900s and the rear shocks removed from the vehicle were 22-3/4" from eye to eye.
For me that sounds like it would give the three inches lift I would like to have.
What do you guys think?
Joe
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
Joe
Joey lift isnt everything you have to find out where the cvs bind at and thats about an inch beyond you wanna go maxing out the axles is horrible for the life of them
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
This is the prob im running into with the p5 with the short shaft axles
264,675
Joe
Going 3" longer on the shocks, if they do not compress at a static setting as much as the OEM shocks it may bind your CV joints due to the increased angle. One way to test would be to lift / hoist your Pioneer off the ground undo the shocks and let the a-arms droop to 22 3/4" at the mounting brackets and see if there is any binding as you rotate the tire.
39,078
I've got a heavy vehicle so it will probably squat a little. Also, the Fox shocks are adjustable. I may buy some soon because I've got to get rid of this HL lift bracket. At worst case, I may have to make a bracket like @bagotaco and check into limit straps. If I can find some pull offs for a couple hundred bucks it would be worth it.
If I get some new shocks, I'll keep you guys posted.
Thanks for this thread.
Joe
Reactions: jak9922
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
Tiss what i was saying but with your fantasy numbers @JACKAL gosh
39,078
With my HL on the 3" setting and the vehicle off be ground like shown below, the CV's will not not bind and operate smoothly.
Another note, with the current setup on my P700, the coils on the top of my shocks are compressed. Therefore, I've got single rate coils like the 2014 models. This thing rides ok but it could be better. I'm thinking that the fox adjustable shocks are the ticket.
Joe
Reactions: Tflynn
BOX2
box3
