Sticks and floorboard
Johnny
Johnny
I went on a long ride with my daughter 2 days ago and for the second time I had a stick damage me Pioneer.
Both times it has been from backing up.
The first time I was on a trail where last years tornado had the trail blocked, I backed up, heard no noises, was turned around and heading back, heard something, my daughter looks out her side and seen a branch I was dragging with us. I get out, a branch had come in from behind and punctured a boot up front.
Recently similar situation, backing up and a larger branch punctured right through beside of my leg, right where the side panel joins the inner panel under the seat. Hit my leg a little but didn't break the skin.
I just hope I can get the plastic pop rivet to go back into the original hole.
Will Dealer service folks complain about after market skid plates?
Thanks.
63,337
Hello @Johnny
A good set of skid plates and a-arm guards is what you need.
Some dealers complain about everything. Its like its a burden for them to do work on your machine.
Are you just talking about a oil change? If so many skids have access to the drain. But check to make sure. If you look at the [HASHTAG]#RMP[/HASHTAG] skids they actually use the factory access door. So its no different then changing oil on the OEM skid plate.
However.. If you have a issue outside of oil change that required the removal of the skid-plate I could see the dealer attaching extra charges for accessory removal.
Hello @Johnny
Some dealers complain about everything. Its like its a burden for them to do work on your machine.....
Service is where dealers ACTUALLY make money they complain so they can justify charging more.
Reactions: OutdoorEd
Johnny
Johnny
Thanks for the replies, yes I do need the extra protection, the style of driving I do, with me not be able to drive hard and and take the bumps and being so wooded here "in these hills", I just love the old over grown trails I used to ride way back in the day, old coal mining tram roads.
I guess I can take the skids off myself, before I take it in for servicing, then they can't say anything
I will most certainly do some reading on your recommendations.
I have done a ton of reading so far on the 700 threads, trying not to post on what others have posted on in the past.
265,256
Get a full set of UHMW skids like these: http://sssoffroad.com/detail.php?id=171692
They will protect you from the stick, slide over rocks much better than aluminum and with a 2" hole saw you can cut any hole in the material you desire for oil change grease zerk access, etc,. I do believe these from SSS offroad are already dilled out for oil changes though.
Johnny
Johnny
Thanks Jackal, I will look at this more after I get home from camping. They look good from the pics on the site, how do the arm guards connect? I'm extremely interested, but the funds right now.... It will happen hopefully soon, but I also know that I am going to need a plow before winter, not sure how much that is going to set me back lol.
I have the winch, but man those sticks on the trails are driving me nuts!
265,256
Almost all A-arm guards attach with 4 half round metal clips with a tab on one end that goes over the lower A-arm tubing and a bolt and washer go through the guards screwing into the metal tabs.
