Where are the after market fender flares?
hurld
hurld
129
159
Just venting here, but this is the last accessory I want for my Pioneer and nobody makes them yet?!
Re: Where are the after market fender flares?
Agreed someone needs to produce a set.
Elkhunter
Elkhunter
345
453
Minnesota
I agree ! I need a set. Every time I take my pioneer out the side doors are covered in mud right away.
63,364
Yep, Love to get a set also.
Seen a few custom jobs that looked good. But I think a company with the means could make it look factory.
Revproaep
6
Musbusters have them as of 04/15/15
scott
scott
1,212
1,354
lyman, South Carolina
I think they have the rears for the P-4 now. The rears look pretty good from the pics.
scott
scott
1,212
1,354
025
Th
026
027
028
The rear fenders...
Beacheagle70
Beacheagle70
Image Image
I installed the mud buster extended set for front and rear. Then first set of fronts were the option set with mud flaps. I have 28x 14's all around and the mud flap design flipped when it hit the tire on a turn a folded up and destroy the mud flap and lower half of the flare. Mud-busters replaced the fronts (at cost) with a new design that works with 28"s without any lift. See picture. Their back pair does not completely cover the ROPEs so I used the old fronts to add a section to the rear which covers the ROPS piece and the bed, The rear now consists of three pieces, due to the lift feature of the bed. The reason for the red reflectors was to cover the extra holes the were on the pieces I salvaged. Seems to work fine, I sent the solution to Mud-busters. Not sure If I attached the pictures correctly, I seem to have issues when using an I-pad. Email me if you need more detailed shots.
[email protected]
bobbyhill
bobbyhill
Junior Moderator
1,271
952
Smithfield, VA
Looks sharp!
66,097
If you have to make it through any 64" gates these won't work. Just getting the roll cage through can be very close. Just an observation.
39,079
Good idea with the fender flares!
39,079
They'll return to original shape if you have to squeeze thru....don't ask me how I know. Actually, you guys probably already know.
Joe
