BOX1
P700 Wiper Wiring Diagram
hobbes
16
12
The reason why I wanted a DPDT relay was to maintain the setup of the original circuit to some degree, this means that when I power the motor I can turn the power off from the yellow wire all within one relay and then power the yellow and join the red and green when i shut the switch off. to maintain the OEM circuit with SPDT relay I have to use two. Now if I power the yellow wire constant then I would only need to use one relay which is another option I have if I don't want to maintain the circuit that I currently have from Honda.
I see what your saying, not sure why Honda did it that way, or used switched Neg on a machine where everything else I've found is switch positive. My power feed is switched with the ignition. The yellow just goes to ground. The DPDT relays are impossible to find in a weathertight version.
318,063
@AKRider i found this. Thanks to everyone here in this article. It's for the 700 but should cross over
AKRider
AKRider
1,402
3,224
Palmer, Alaska
@CumminsPusher you are the man! Thanks, and thanks to everyone that did all the work on this.
Reactions: CumminsPusher
AKRider
AKRider
1,402
3,224
Palmer, Alaska
@Madore128 Check out this post. It covers the windshield wiper wiring really well.
AKRider
AKRider
1,402
3,224
Palmer, Alaska
Who speaks electrical engineer?
I need help deciphering this diagram for a wiper motor, I cannot disassemble the assembly without the high likelihood of destroying it.
UPDATE
This is for everyone who wants the Wiper but not use the Honda Aux Panel.
28372eca505fc83827bb1592efbfa2a5
Spifyd,
The non-North Americans switch the Negative(glad I had fuses) I wouldn't have figured it out without you pointing me the right direction. Many thanks.
Hi @ohanacreek , thank you for this information. I was racking my brain trying to figure this out. I hate the idea of adding another relay when I have the Cooper Bussmann PDM, but this is better than using the Honda Accessory panel.
318,063
You'll have to use the 5 pin relay I believe. I've been thinking about it and I can't see how to use the bussman other then for a trigger wire. I remember using a separate relay as well.
AKRider
AKRider
1,402
3,224
Palmer, Alaska
I've already found one at the Oreilly's down the road. I'll pick it up in the morning and start the madness of wiring. I'll attempt to remember to take pics and post it to my build. No promises, though. I'm terrible about remembering to take pics... lol
318,063
Grab the plug for the relay as well.
AKRider
AKRider
1,402
3,224
Palmer, Alaska
Good idea. Hopefully they have it. If not, no big deal. I have enough connectors and wire to make a nuclear weapon... lol
Sent from my SAMSUNG-SM-G870A using Tapatalk
No problem took me twenty blown fuses, finally got some help from a fellow member myself
AKRider
AKRider
1,402
3,224
Palmer, Alaska
They didn't have one so I wired it myself. Everything went well. And, I forgot to take pics during the progress... lol. I got it all dirty on Saturday. After I clean it I will take some.
318,063
Awesome! I hope that helped! I had nothing to go off of since my new one doesn't have a wiper. That sucked I hate not being able to help a friend
Sent from iPhone
AKRider
AKRider
1,402
3,224
Palmer, Alaska
Sent from iPhone
You pointed me in the right direction. I just used what you gave me to help another here, and if he doesn't understand it I can now explain it. The people here are awesome!
318,063
And that's a fact!
Sent from iPhone
Reactions: AKRider
mole
23
16
Belle Vernon,Pa.
UPDATE
Spifyd,
Just wanted
mole
23
16
Belle Vernon,Pa.
Just wanted to thank-you for wireing info on wiper install .I followed your diagram &wiper works just like it should.Being as I have almost less experience wireing than I do with a computer I was shocked & happy.
mole
23
16
Belle Vernon,Pa.
Re: Wiper Wiring Diagram Help needed
This is for everyone who wants the Wiper but not the Honda Aux Panel.
D3d7aefbeb80b24c4d092963162e0a17
Spifyd,
Sorry, forgot to ask, anyone know how many amps wiper draws?
BOX2
box3
