GROR
FITS: 2016-2025 HONDA PIONEER 1000 SXS M3/M5/M6 WITH INSTALLED HONDA GLASS WINDSHIELD - P/N 0SU85-HL4-A00.
- The wiring harnesses and switches provided connect to a dual battery auxiliary fuse box; no other OEM wiring components or harnesses are required for installation.
- Kit Features a 172-degree 2-speed large sweep electric Wiper motor with Dynamic Park Function.
- Plug-and-Play Wiring Harnesses are designed for easy installation and include high-quality Carling switches for durability and reliability. They connect seamlessly to your existing aftermarket auxiliary fuse box.
- 14” - 18” adjustable Radial Arm, J-hook blade connection. With 14”/350mm J-hook wiper blade and wet kit
- A one-gallon Washer Tank Reservoir mounted under the driver's seat provides ample washer fluid capacity for off-road adventures in any condition
Note: The innovative tank bracket design allows you to store essential items such as toe straps or tire repair kits while maintaining the critical functionality of the storage area.
The Complete Kit Contains:
• 172° Sweep, 2-Speed Motor
• Plug-and-Play Wiring Harness Components
• Wiper Arm and Blade
• Washer Reservoir and Mounting Bracket
• Tubing and Spray Nozzles
• All Necessary Hardware for Installation
