P500 2016 P-500 No display
P
Phillig
5
SC
My 2016 P-500 will turn over but the display doesn’t light up nor does the fuel pump run. Everything was fine until I shut it down for the season about two months ago. It has a new battery. I’ve checked all the fuses except the main fuse. Any ideas what might be the problem? Thank you!
Red500
Red500
6,577
70,673
Greeneville, Tn.
Check connections at the computer under the passenger seat.
Reactions: trigger
Red500
Red500
6,577
70,673
Greeneville, Tn.
I have heard of them going bad before. Especially if they get wet a lot.
Reactions: Phillig
906UP
906UP
15,021
142,687
da Yoop
Check the main relay (or connection to it), it's in the battery box. If it's not coming on that will cause the ECM, dash, fuel pump, etc to not come on. Do you have a shop manual? Supporting members can download one
Reactions: trigger
P
Phillig
5
SC
Thank you. Yes, I have the shop manual. I will check the relay.
Reactions: Smitty335 and 906UP
