P500 2016 P500 - Too many miles?
43,291
Reactions: Mudwing
KYhillbilly
KYhillbilly
553
1,663
Ashland, KY
says used for ATV tours yet has a blade attached, the two don't go together. If used for tours speed would be limited as in a group you go slow however given it has a blade it may have been used for maintaining trials for tours. Check it out and see how much wear and tear it has and offer them $5500 if it check out. They can only say no and then you can negotiate from there.
322,675
I gotta agree, that’s the first thing I noticed.
cras108er
27
56
Alaska
Thanks guys. I heard back from him. He runs a tour company that exposes customers to an “Alaskan Adventure.” Let’s just say that a vehicle with 3,700 miles of water crossings, mud holes, and vacationing tourists on someone else's borrowed (rented) vehicle is a little too much “use” for my blood. May be a good deal for a gear head, but I think I may have to pass on this one.
Reactions: Mudwing
906UP
906UP
14,392
136,724
da Yoop
I think you could get it for 5500-5700, that's $3K plus less than you were quoted for a new one. Are you comfortable doing maintenance/repairs if needed? If so even if it needed a top end or clutch overhaul, probably the 2 major things, you could save a lot of money. These rigs are typically tougher than an anvil and damn near impossible to break unless completely submerged while running, even then they hold up very well. I'd be more concerned about "crash" type damage from being a rental than the plow on the front.
Reactions: Mudwing
906UP
906UP
14,392
136,724
da Yoop
You responded while I was typing, no worries, do what your comfortable with :)
Reactions: Mudwing
