P1000 Solved - 2016 Pioneer 1000-5 Stalls when Slowing down from 35mph/Downshifting
HBarlow
HBarlow
1,616
6,000
Daniels, WV
That's confusing. Does it idle normally or stall when you start it in N (neutral)?
Does it stall if idling and you place the shifter in H (high range) or L (low range)?
aareed
aareed
19
58
Texas
after driving for about 45 minutes on a warm day (85+) when I am driving at 45mph and let off the accelerator it dies. Rolls to a stop, and will restart immediately. Has nothing to do with Idle.
208,011
Mine was doing weird stuff and the last time I took it to the shop they found air injector and both fuel injector leads bad and replaced them and seems to be fixed?
Reactions: Lady01 and Rick53
HBarlow
HBarlow
1,616
6,000
Daniels, WV
You keep saying that but no one can diagnose it based on your limited information. Why do you refuse to answer questions?
Since you already know everything why did you post your problem here?
Reactions: Lady01
aareed
aareed
19
58
Texas
Does it idle normally or stall when you start it in N (neutral)?->Idles Normally, does not Stall
Does it stall if idling and you place the shifter in H (high range) or L (low range)?->No, Does not Stall.
There is no problems with Idling. Issue only occurs after the machine has been running (45 minutes or more) at slower speeds (under 15-20mph) and then only driving fast and then slowing down (down shifting from 6th Gear). Problem also only seems to occur if the temperature is warm/80's or higher. . . . I have tried to reproduce the problem on a cooler day (temps in the 60s) and it doesn't repeat. It only happens as far as I can tell when it is hot out, and the machine is hot as well.
Reactions: Lady01
05Willys
05Willys
528
3,307
PA
Seems to me like something is loose. It seems as though when you let off, the g forces of engine braking may be moving a wire or connector enough to cause a temporary faulty connection. Maybe that is why it does it only at higher speeds. The ecm seems to see something it don't like temporarily. I would also look for wires that may have rubbed on something. My Jeep would shut off randomly similar to this and I was able to put it in neutral and start it right back up while still rolling. Are you able to do that? It was a nightmare to track down the problem. It had a crank position sensor wire that wore through and was intermittently shorting on the ac condenser line. The higher ambient temp thing baffles me though. Maybe because the wire is more pliable at warmer temps. Good luck with this. Please let us know what you find, I'm intrigued. Thanks
Reactions: Lady01
bumperm
bumperm
1,845
6,639
Gardnerville, NV
When it's dying, is it at what would be or is a shift point? I'm wondering if it has to do with the dual clutch operation and timing of that. Just a WAG, but if when downshifting the releasing clutch is sticking, perhaps it's adding enough drag to cause the engine to stall?
I may be way off base here, as I'm new to all this, but if the above carries any water at all, then a way to eliminate that or the shift control motor as a possibility would be to downshift manually with paddle shifter to see if the motor dying has any relation to the shift point.
Reactions: Lady01
HBarlow
HBarlow
1,616
6,000
Daniels, WV
The symptoms sound like the DCT clutch for 1-3-5 is not disengaging just prior to the machine coming to a stop. The fact that it only occurs when ambient temps are 80°+ makes it more confusing to me.
If you have the opportunity when the 80° or better temp condition is met try shifting the gear selector into neutral as you slow to stop then back into H or L instead of stopping while in H or L. That, at least to me, would confirm it's a clutch, clutch solenoid, or computer program issue.
I think you're going to be forced to take it to a Honda Powersports dealer with a good, trained tech who understands the DCT.
Reactions: Lady01
P1K5Dave
P1K5Dave
2,150
8,047
Petoskey, MI
Have you gotten to that electric shift motor yet? So far, that looks like the most likely explanation offered...I would eliminate that cause before going all the other directions.
Reactions: Lady01
HBarlow
HBarlow
1,616
6,000
Daniels, WV
What does the "electric shift motor" do?
Reactions: Lady01
slowdryrider
slowdryrider
562
751
Canada
FYI the electric shift motor does the actual shifting of the gears . Both up shift and down shift. If you didn't have this motor you would have to shift the trans manually. Right next to the shift motor is a shaft that sticks out so that if your machine is stuck in gear you can put a wrench on it to manually shift it. BTW that wrench is in your tool pouch under the hood of your machine.
Reactions: Lady01 and aareed
aareed
aareed
19
58
Texas
That sounds like what could be happening. I have put it in MT mode and without downshifting myself, just slowing down, it also died. When it does, the engine is still engaged and continues to spin/braking me until I am almost at a stop. At that point, I can hear the transmission downshifting back to first.
Reactions: Lady01
aareed
aareed
19
58
Texas
I took a look at where it is at, seems like it might be hard to get to and I couldn't find a video or any details on what is involved in taking it out. I ordered a new motor and will go ahead and replace it this weekend. If anyone has a how to for getting the shift motor out, it would be appreciated. Seems like it is in a hard to reach spot. . .
Reactions: Lady01
aareed
aareed
19
58
Texas
When I first started having this happen, I tried several times to shift to Neutral as I was rolling to a stop. It did not like it and I could hear gears grinding. . . Didn't seem like it was a good thing to do.. . .
Reactions: Lady01
aareed
aareed
19
58
Texas
No, it won't shift to Neutral without grinding and the engine is turning so I don't want to hit the starter. I wonder if there is something that when it doesn't shift correctly it kills the motor?
Reactions: Lady01
HBarlow
HBarlow
1,616
6,000
Daniels, WV
Gears should not grind by shifting into neutral when rolling . . . unless one or both of the clutches are failing to release.
Reactions: Lady01 and 05Willys
P1K5Dave
P1K5Dave
2,150
8,047
Petoskey, MI
You're not supposed to move your shifter while moving. Full stop and idle.
Reactions: Lady01
P1K5Dave
P1K5Dave
2,150
8,047
Petoskey, MI
You went ahead and bought a new shift control motor? That's a couple hundred bucks, right? I would have tried cleaning mine up first. :oops:
Anyway, do you have a service manual? It looks pretty easy to get to if you remove the rear floor panel.
Reactions: Lady01
slowdryrider
slowdryrider
562
751
Canada
When mine acted up I cleaned mine up and it worked fine. For peace of mind , I did replace it with a new one and it's working perfectly. I bought this one from amazon it fits and works perfectly. I kept my old as a spare.
Mine is a P3 so less to remove . The motor is held on with 3 10 mm bolts. It's simple to do.
