P700 2017 700-2 Deluxe Dual Battery set up.
buttesink
16
17
RWC CA
Good afternoon all,
I'm new to the forum but have I seen a lot of great info and is much appreciated.
Starting a new project, installing dual "True" battery isolator kit. / Odyssey pc925
Looking at Cooper Bussmann 15303-2-6-4NG Fuse Relay Box
Looking at some videos, most all suggest a "Stinger" & 100 Amp disconnect, I'll get them
For the must part it seems not to complicated but I'm sure I'll be opening a can of worms.
I currently have installed-- warn winch, (1) bar light, pod lights and wipers.
The wipers I'd like to run with bike running, all additional accessories and maybe some additional future lighting, along with the winch, I'd like the option to use with the ignition off
I think I'm going with Pioneer Switch Panels and accessories & OTR rockers.
Any help / tips on the wiring "Start to Finish" :) would be great!!!! or additional items that you came across during your installation
Thanks Ken
Reactions: Mudwing and TripleB
bullyx
149
450
new york
following this thread. I'm in same boat, but don't have a stinger . Is that needed? Or is that for a cleaner install?? Read somewhere its not needed????
03mossy
03mossy
282
1,114
MN
  2. Other Brand
Following also. I plan on this same project this winter.
Bigseff23
97
172
Lakeland Florida
I don't know why everyone wants to run dual batteries when there's more than enough room under the driver's seat for a full size automotive battery which actually would be easier to hook up and have way more power then 2 small batteries. maybe I'm just different but I feel like going with just one automotive battery is the better setup
David-1964
David-1964
38
99
Waterloo
Good afternoon all,
Thanks Ken
David-1964
David-1964
38
99
Waterloo
I used all the normal parts, but if I had to do it over I would not use the 12 slot CB box, 6 is enough and takes up less space.
