P1000 2017 Clutch dragging problems
Lisa86
Lisa86
Chief Sammich Engineer
451
5,616
Ohio
  2. Talon X LV
My 2017 3 seat 1000 is pulling when in gear with no throttle. I attempted the clutch relearn but couldn’t get it to do it. I think the seat belt bypass is keeping me from the relearn. My question is what could be the cause. What can I expect to destroy by just riding as is.
Plowboy1466
Plowboy1466
300
1,502
Ashland, Ohio
My 17 does it to. I didn't seem to notice it before the clutch housing upgrade. It's definitely worse when it's cold. I did the the clutch relearn a couple times and it didn't make a difference. I hope someone has a good answer!!!
TripleB
TripleB
15,686
140,769
Caryville, Tennessee
I have a new clutch pack in case it s***s the bed. I have the seat belt bypass and have done the relearn numerous times.
0860silverado
956
1,845
louisiana
I've noticed that when my engine oil gets toward the end of it's service life, my clutches start dragging too. As soon as I do an oil change, the drag goes away. Is your oil past due for a change?
HBarlow
HBarlow
1,634
6,084
Daniels, WV
Is your engine idling faster than it should? Compare your idle rpm with someone else whose clutch is not engaging at idle.
If the clutch is dragging (partially engaging) it is accelerating wear on the clutch pack. If it continues I think you'll see early clutch failure.
Reactions: Lady01 and Squeegee
TripleB
TripleB
15,686
140,769
What does it do when attempting the relearn? Seat belt bypass wont affect anything.
It just wasn't getting warm enough idling. It wouldn't even start the relearn even though it had been running for 15 minutes or more. I just give it some throttle for a couple of minutes and the relearn worked then.
HondaTech
Even when the 2 bars on the coolant gauge first pop up the unit isnt warm enough.
The oil has to be a certain temperature before the relearn will process.
Reactions: Lady01 and TripleB
