BOX1
P1000m5 2017 Honda Pioneer 1000-5 $12,750
bigfoothunter
Texas
For sale I have a 2017 Honda Pioneer 1000-5 with lots of extras! Has ~5,700 miles and roughly ~800 hours. It is used almost daily so these numbers will change a little. I bought it back in 2019 with ~2,000 miles on it. Located in Canadian, TX. 16da79600e5578a1d01a03b467cca1cd
I have very meticulous maintenance records since owning it and have completed most of the maintenance myself. It has an engine oil, engine oil filter, DCT filter, and sub-transmission oil change within the last month. (I have started changing the engine oil and filters on it every 100 hours instead of 200, I figured it wouldn't hurt). It is always garaged when not in use. I have used all OEM parts and fluids for maintenance. Clean title in my hand. I am selling because we are wanting to move to a slightly larger UTV. I have never been offroading or taken it on trails/mudding...I use it every day for ranch work.
Door bushing rattle fix on all 4 doors
Honda poly 2 piece flip up windshield
Honda plastic roof
Switch panel and Extra/larger cup holders with digital voltmeter and usb charge ports
LED lightbar on front bumper with switch mounted in dash
Led light bars for lighting cargo box and as reverse lights with dash mounted switches
Electrical bus and fuse box for LED's
Vent extension kit on all gear boxes and tanks
Rubber mat cut to fit in cargo box
Brand new Tusk Terrabite Aramid rear tires
Tusk Terrabite front tires
All tires have Tireject in them to reduce leaking from a puncture
Extra rear Sedona Coyote Rear Tire (75% tread left)
Extra OEM engine oil, filters, air filters, etc.
Side nets
Original Owners Manual
Clean Title
Simply selling because we went with a little bit bigger UTV.
A little history on it:
When I bought it, one CV boot was bad on the front driver side axle. I went ahead and replaced it with a new SuperATV axle at that time.There is a crack in the front windshield (see photo). The clutch was slipping, so I took it into the dealer and both clutches were replaced in 2020 due to the factory recall by the dealership. The front "Honda" emblem has been cut out (so that I had easier access to clean out the radiator with a vacuum). There is a small dent in the driver side rear roll bar near the tailgate (see photo), was there when i bought it. Other than that, we have had no issues or problems with the unit.
Thanks,
Adam4e7ec7aa3cb0b70fce075681c4ee9f8e
6d5c5b6d8f2aff81524a864f9ed0a906
D3939552312d29bfd06eb57455e8ece0
7fc41db6d6923ee1f8ede74b86780641
2a8fa83a7f0e10613e23f972018c16a4
2838f04bdefd1dee2aa23950ab308ecf
Ce8bea699d3f91155b5ce3e2243c2e17
4c026c381f5cfa0e2578fae63bb7ed12
B70fbbd45d9b13006fb44aa2c7cfd8a2
794213422b84e3c24b90594ad37894e7
E82dae27f9d65e32742f4b1746d20c66
0db16c8c1c17595890447cbc098be8ba
Sheriff Chief POIDH Enforcement Officer
103,460
Might be mostly location, and some get scared of the damage and other issues it had prior especially to the ROPPS. Wouldn't bother me, but to most it does. Plus you can get a brand new EPS with warranty no damage for a few grand more.
just food for thought.
Good luck! Hope u find a taker.
BOX2
box3
