P700 2017 honda pioneer700-4 blowing starters motor kicking back when trying to start.
F
Festis
5
I just started having this issue about a month ago put 3 starters in it adjusted valves thought I was good to go on the second one. The original one fell apart bolts on side where loose the gear stripped replaced with a different one lasted approximately 20 starts gear stripped. Adjusted the valves got another one used for a couple weeks seamed to be doing good until yesterday. Was out fishing relays froze thawed them put back in rolled over a bit wanted to start but would kick back once in a while broke magnets in that starter had another one put on started 3 times kicked back broke the magnets in that starter. The last two where cheap starters the first one was not a honda but it wasn't a 50 dollar one. Some people said to put a honda starter in just have trouble spending that much and have it happen again. Trying to figure out what is causing the kickback seems like that is what is taking them out. As for the original it was kicking back with that one also I just assumed that the starter was falling apart. Any ideas what would be causing the kickback when trying to start. Figured it was the valves. But thinking something else now. It runs fine when it starts just can't keep a starter in it. Just looking for a place to start. Cam, torque reducer, flywheel. Also did do oil changes after replacing the ones with stripped gears. Also seams like the one the gear stripped in was caused from the kickback not from rolling over that starter still works on the bench just the gear is stripped. Any input would be appreciated.
Glock21user
Glock21user
" Nothing succeeds like excess "
1,822
9,034
Livingston county, Mi.
Any chance you used the search function at all?
This very subject is covered in great detail if you search.
Good luck with your project.
F
Festis
5
Yes but other than changing the cam, torque reducer, clutch flywheel and starter nobody gave a definite answer to what the problem is. Some people changed the torque reducer and still had starter problems.
Reactions: Glock21user
Glock21user
Glock21user
1,822
9,034
Well s*** those don't help.
Has anyone found the issue causing this and resolved it ?
Let's hope the Pioneer Family has some good answers.
DRZRon1
DRZRon1
1,384
4,272
PA
How many miles on this thing and have you ever had the cam replaced ?
Also - u have any pics of the machine u can share with us - love sxs porn
if that thing has a decompression release on the camshaft - I’d check to see if decompression is working since it’s easy to check to rule that out
F
Festis
5
It has 5555 miles 619hrs. Never had any problems until now other than oil changes and regular maintenance. And the relays freezing when I'm ice fishing I usually carry a extra set in my pocket. Yeah I'll probably tear it back apart next weekend and see if the decompression is working. Sorry no pics.
DRZRon1
DRZRon1
1,384
4,272
PA
Is it possible that u turn the engine over by hand and look at exhaust valve and see if it bumps a little before opening?
Just thinking about decompression mechanism, bent push rod, etc…..
Glock21user
Glock21user
1,822
9,034
I am going to throw out the obvious and ask what your cranking voltage is?
The batteries in these things suck ass to be honest.
Just a suggestion as I went to a full on struck battery under the drivers side seat and it helped me alot.
Just throwing it out.
Hello_Darkness
Hello_Darkness
596
2,446
Just to the right of nowhere
Stock battery works fine for all of my customers, the machines not meant to run a whole trucks worth of equipment.
The charging system isn't strong enough to support that much battery anyway.
Reactions: pappyo
F
Festis
5
Yeah i just have the original style battery in it but is a few years old now and I actually just ordered a new one after the second starter went out. While I was charging the battery before I tried it with the last starter.
Smithy
Orange Australia
I was talking to a guy that fixes these for a living last year about a problem we are having where the rear cam bearing starts to shed metal and causes a knocking sound when running and he happened to mention what sounds like your issue. He said you need to be careful that you are not applying any throttle while cranking as it causes the engine to ‘kick” when it fires which causes the starter gears to strip and damages the starter [I don’t remember the nature of the starter damage]. He was probably a little more descriptive when he described why it happens but my take away from the discussion was to make sure that our users knew to not have their foot near the throttle pedal when cranking. Hope your issue turns out to be that simple.
Reactions: pappyo
P
pappyo
613
2,453
1st. WELCOME Forum Upstate Central New York
Thank you <> for becoming one of the <> many good people and informative members of the Honda Family Forum.
A few are more full of themselves than others ( they mean No harm <> neither do I
They ALL Like Pictures
Smithy
Orange Australia
1st post <> Keep them coming
Introduction Post & Pictures of you Toy ( before picture Police shows up )
Enjoy the Toy and Make Memories
SOS MEMBER <> SLOWER/ OLDER / SMarter ( work in progress on last one )
