P1000 2018 pioneer 1000 wont fire up!
88dunerider
48
59
oregon
So I've got a 2018 pioneer 1000, usually gets driven everyday for 10-15 min . Went to start it up today and it just cranked , never fired up . You can hear the fuel pump turn on , all the dash lights work , even headlights . Temps here are 40-45 during day and 30-35 at night . I've never had an issue getting it started until today. Honda dealer is 2 plus hours away so trying to avoid a trip! Any ideas ??
906UP
906UP
14,404
136,861
da Yoop
Air, fuel & spark are what's required for an engine to run. I always break it down to the simple things to start with.
Air? Is the air filter clean, probably but it can be easy to overlook
Fuel? You can hear the pump run, that's good. Is it getting to the injector? Try spraying some carb clean down the throttle and see if it fires.
Spark? You can get a inexpensive spark tester at an auto parts store or use a screw driver in the spark plug cap & have someone crank it over while holding it 1/8" from the frame or engine, you should see a spark.
Gabbas
Gabbas
280
701
Humboldt, Iowa
Could be the injector wire. That's a common issue. They sell replacements in the SXS store on the forum. Check the wires. They tend to break easy.
Sent from my Pixel 4 using Tapatalk
88dunerider
48
59
oregon
I have not checked airfilter or sprayed anything in the carb yet or checked the spark plugs. Thats on my list to do tomorrow. I pulled the stock battery and put it on a charger....is it possible the battery doesn't have enough juice to start it but enough to light the dash up and run headlights?
906UP
906UP
14,404
136,861
da Yoop
Possible..... See how it does tomorrow and report back, there's lots of helpful people available on the forum.
Reactions: ChadD
906UP
906UP
14,404
136,861
da Yoop
This crossed my mind as well, that's why I suggested using carb clean in the throttle. If it fires with carb clean it's a fuel issue, just need to do basic troubleshooting to find the system that's causing the problem.
P1K5Dave
P1K5Dave
2,260
8,463
Petoskey, MI
Pull and clean your spark arrestor, it's one possible cause.
Reactions: 906UP
88dunerider
48
59
oregon
Does anyone know where the grounds are located at ?
Russ989
Russ989
22,642
147,257
88dunerider
48
59
oregon
There are a few but I don’t remember off hand. I’ll look when I get home.
When I bought it brand new , almost 3 years ago to the day , after 3 days of having it , it would start up but go into limp mode. I took it back to the dealer and after 2 weeks there they found a loose ground. Which after tightening fixed the problem. Which is why I'm skeptical maybe that could be an issue now ?
Reactions: Russ989 and 906UP
