2021 . Having trouble hooking up a whip
NTCPrezJB
NTCPrezJB
Retiring Member
110,985
968,655
Hidden
2021. Whip installation kicking my but. I want to hook it up to a rocker switch .
How can we help? What trouble are you having?
Likely you will have two wires on the whip(s) … one positive and one negative. You can insert the switch on either wire technically. Most switches are done on the positive line though.
If you’re looking for help on witch pins of the switch to use…post a pic of the back of your switch and someone can likely tell you from there.
If it is one of the factory switches you are trying to use…tell us which one. Again a pic could help.
115,809
Welcome from Michigan!
Pics of what your doing helps. There is all kinds of whips out there and wiring is different for all of them.
Most importantly is pics of your rig tho. You see Its Rule #4 when you join/first post. The statue states…Must provide pics of your rig with info of it and yourself. You could be a walking dead Biden supporter for all we know🤣
Pics Or It Didnt Happen!
