P500 2021 P520 Doors fit P500
P
pappyo
597
2,400
After several conversations with several Honda Dealers I found 1 that called Honda & got a straight answer.
They DO FIT. ( on order will soon know for sure ?? ) MSRP: $641.95 BLACK
The NEW STYLE Better Fit , Better Seal , Only 1 latch to open requires unzip window reach inside use OEM Latch ( remove the OEM lower plastic door & reuse OEM Latch ) nets can be still used if you like them.
The 2021 P520 Camo pattern is different than 2020 P500 & earlier.
Will have a set of P500 upper 1/2 doors for sale soon. ( SOLD 2ND DAY on CR. )
great shape , include lockable latch used when towing on a trailer ------ Up State N.Y.
It's only money if you don't Spend it. Those you leave it to Will.
20200725 122217
P
pappyo
597
2,400
The doors are at the dealer 1 1/2 hour away as of yesterday.
Snow here in North East hampering safe travel.
Should be able to P/UP tomorrow.
Reactions: J80
208,728
The doors are at the dealer 1 1/2 hour away as of yerterday.
Be patient, no since in risking life and limb.
Reactions: J80 and pappyo
P
pappyo
597
2,400
Honda recommends NO. ( On both P500 & P520 DOORS)
I Do & Have TOWED Both Pp500 & P520 With Doors on & Open Trailer Without Any Problem - using latch method described below.
Depending on the rest of your enclosure while Towing Air Pressure accumulates. ( Vent is Needed to let Pressure Out )
My Cab is fairly well sealed to hold heat ( installed a Vent in the back panel of the roof ).
As a Safety Measure I installed a Lockable Tee Handle -- ( From a truck cap Hinged side Windows ) -- ( need 1 each Right & Left )
When rotated the inside holds against the roll cage near windshield. ( only use when towing )
Pop Rivited a piece of aluminum in the door frame to accommodate the Tee Handle. ( T-Handle can be seen in above Post 7# )
Reactions: J80 and Mudwing
KYhillbilly
KYhillbilly
553
1,663
Ashland, KY
looks like a much better fit, wonder if i can just order the plastic piece for my 500 doors, looks like that would help fitment. And i tried towing 500 with doors on and had the passenger and drivers side bungeed together. had one blow off on interstate, luckily it didnt damage it and i could find it. So now i take them off or use my towable cover on it.
Reactions: GrnP500 and J80
P
pappyo
597
2,400
After having Both P500 & P 520 Doors.
1 - Invest you hard earned cash in the P520 DOORS -- Not just plastic piece.
2 Sell the P 500 Doors -- those with a Plow are looking for doors)
FYI : The lower OEM Plastic Door -- has to be removed --- Only OEM Latch is reused -- NO More 2 Doors BIG Improvement.
Only negative : The Window Zipper is Ft. to Rear ONEWAY & you have to unzip 8 to 10in. to reach in & turn the OEM Latch.
Simular to buying plastic windshield scratch it up & then go GLASS .
Pictures show Vent & Tee Handle Latch
Lucky that door didn't get run over.
20210306 170039 20210306 170039 20210306 165657 20210306 165947
