2023 Talon R 4-Seater 6,000 Mile Report
hondabob
1,294
5,142
Prescott Valley, AZ
I'm at 6,200 miles now. The new 30-inch BFGoodrich mud terrain TA KM3 tires are better than I expected. The OHV specific KM3 tires are still not showing much wear for 1,000 miles. It looks like I will get around 8,000 miles out of them. The suspension is really good after I replace the rear 6-inch tender springs with 10-inch Eibach springs to fix the loss of ride height. The factory settings were good, but I was down to 8.5 inches of ground clearance at a bit over 4,000 miles. I adjusted the suspension to 13.5 inches of ground clearance and no problem now. I added one inch of preload on the front for 13.5 inches of ground clearance up front. The crossover rings needed adjustment to avoid spring coil bind.
20241025 105623
1000006950
