2023 Talon R FLV 4-seater 4,000-mile report
hondabob
1,281
5,089
Prescott Valley, AZ
The suspension was ok at around 1,500 miles but the rear springs have sagged so I have lost 3 inches of ground clearance. I have about 250 pounds in the back. I ordered new 12 inch long tender springs so hopefully the new springs will allow some adjustability and fix the problem. The factory tender springs are around 6 or 7 inches long. Honda set the crossover rings up high so I get a good soft ride and it does cross over before spring coil bind.
The rear tires won't last as long as the Maxxis tires on my 2019 Talon. I will be installing 30's next month. I put a paint mark on all three U-joints and can inspect them without removing the skid plates. Just like my 2019 and 2020 Talons no break down problems.
My buddy bought my 2020 Talon. He did the oil change, sub trans, and front and rear dif oil. We removed the skid plates, and he did a complete inspection. I showed him how to check the marked drive shaft U-joints to make sure the bearing caps don't turn.
10
11
12
mmjsport
61
195
California
Nice. Yeah my rear was super low also after adding rear weight. I had a suspension shop do springs and valving which made the ride quality improve a bunch and the rear air higher. Only when I add two more adults in the back does it drop again but there is plenty of room left for more adjustment if needed. You’ll really enjoy the new springs.
Reactions: ChadD
hondabob
1,281
5,089
Prescott Valley, AZ
The stock tender springs don't have enough adjustment to get the ride height up. I'm at 8 inches ground clearance after 4,000 miles. I have my little Suzuki loaded in the back seat area but no tools. Changing the springs is a PITA without the large spring compressor. I ordered Eibach tender spring a size up from what I had on my 2020 Talon. It wasn't enough so I have 3 sizes up ordered plus a spring compressor.
11 12 13 61D5 79
