P1000 2nd battery wiring question.
MuskyHunter
MuskyHunter
94
216
Indiana
Bought the true kit from the club store. Also got the key on adapter so I didn’t have to tap a wire. For now all I’m installing is a winch.
1. what else do I need to buy?
2. what is the key on power adapter for?
3. can I hook the neg from the true isolator to the neg battery post?
4. the kit came with an 80a relay. What is it for?
Gabbas
Gabbas
280
700
Humboldt, Iowa
1. Stinger relay, if you want a fuse box.
2. The adapter runs off of your 12v acc from the 12v plug. It has a red wire coming off of it for you to run your "key on trigger"
3. There is no negative on the tru isolator. They are both positive. Read the directions. They are fairly easy to follow.
4. The 80amp relay like the stinger?
This transfers 12v + to your fuse box if you so choose.
In this pic my stinger is on the left and my winch control is on the right.
0582afb10c866495007fe14b56d12b1f
Sent from my Pixel 4 using Tapatalk
Ridinfool
Ridinfool
36,145
386,038
Western North Carolina
I used the key on adapter and ran the red wire to a buss block so I could then run all of the things I wanted to be triggered, stinger, isolator, winch relay to be hot when key was on. I also screwed a black buss bar to the cross bar above where the second battery goes, and ran the factory winch ground to that, then grounded the second battery stinger, volt meters and fuse block to that.
Hillbillytnt
Hillbillytnt
517
1,897
Ky
If all you have rt now is a winch you should be good to go. You will want a fuse box later and that’s when you need the stinger. So this is a good starting point. Follow instructions for kit. Yes you can hook ground from isolator to 2nd battery. Relay runs dual volt meter and since it already has two hot wires going to it acts as a ground but hook up is simple. Relay - Black to ground on 2nd battery one green to volt meter ( one green is extra so just tape it up) Red is hooked to key on wire.
MuskyHunter
MuskyHunter
94
216
Indiana
I have dual volt meter so relay to AUX and main battery to main on volt meter?
Reactions: Wsmithgunworks
Hillbillytnt
Hillbillytnt
517
1,897
Ky
The true kit comes with a wire to run from the isolator to the meter. One to each side of isolator then to back of meter. It’s a blue wire and green wire inside a blue casing. The relay has 4 wires. 1 black 1 red 2 green Black to ground. You can use 2nd batt. Red to key on wire from the club. Green goes to meter instructions tell you 2nd green is extra so I just taped it up.
JoeyL
JoeyL
276
741
Houston
here are a couple of good threads on this that should help
also i put 3 wiring diagram examples in this post you can look at
the Wiring Diagram Simplified 2 file uses a stinger relay and fuse box for accessories, where the accessories are activated with key on power
the Wiring Diagram Simplified 3 file is set up so the accessories on the fuse block are always on
the Wiring Diagram file is more complicated and you can switch the accessories from key on, to always on, or off
also note that i have an AXON winch shown so yours will be wired differently if it is any other winch than an AXON, just connect it to your second battery and wire it as shown in the instructions.
Reactions: MuskyHunter
Obr1en
Obr1en
0
Nebraska
Thank you for these links, very helpful for my install!
