P700 700-2 charging issue
T
Trochel
14
Minnesota
Trochel
Apr 23, 2020100MinnesotaOwnership
700-2
3 minutes ago
Battery goes dead while driving. Stays fully charged stored. installed new battery. Same results.
battery shows 12.7 with engine off 12.05 with engine running. I’ll assume the battery isn’t
charging. Not sure why or where to go from here. Thanks. Tim
Reactions: Russ989
Russ989
Russ989
22,642
147,257
Trochel
700-2
3 minutes ago
It should be showing 14+ volts while running.
Reactions: Backwoods
T
Trochel
14
Minnesota
I have not checked anything other than the battery. Voltage meter tells me it’s not charging
70Bones
70Bones
888
3,779
New Brunswick Canada
Did you buy it new or used? Does the voltage drop when the key is turned on with the engine off? Have you added any accessories, that could be drawing a lot of current? If so, maybe incorrect wiring?
T
Trochel
14
Minnesota
Bought it used in 2018 it’s well out of warranty 😞
T
Trochel
14
Minnesota
The only add on is a warn winch. My voltage meter drops a bit with the engine running
Russ989
Russ989
22,642
147,257
Sounds like it’s not getting any charge.
HondaTech
Check the plug in front of the passenger side rear wheel.
The large flat plug with 3 yellow wires is the stator plug. I've seen them unplugged before on new units.
If thats fine, check the regulator plugs under the hood. If there all right and not full of dirt or water then there's a way to narrow down the issue through some voltage and resistance checks.
Also while the engine is running, is the regulator getting really hot?
Reactions: Mudwing
T
Trochel
14
Minnesota
Not sure where the regulator is located? I will check the other stuff you mentioned. Thank you
T
Trochel
14
Minnesota
Stator wires are plugged in. Fuses are good. Not sure where The regulator is, or what it looks like.
the battery was at 12.7v before I started it. Checked while running it 12v so dropped .7v
T
Trochel
14
Minnesota
T
Trochel
14
Minnesota
pretty sure I found the problem, once I found the regulator. A stick/brush or something got up into the passenger side wheel well and tore the red and green wire out of the plug that plugs into regulator. New issue. No idea which wire
goes where. It’s 50/50 but not interested in wreck the regulator.
Reactions: Mudwing
HondaTech
If your looking at the regulator under the front passenger wheel well the red wire goes in the forward hole and the green goes in the rearward hole.
T
Trochel
14
Minnesota
New problem. No power to anything. Is there a spare 40 amp fuse on the 700-2?
