P700 700 front axles problems!!!
motorman18
439
277
Laurel, MS
And your lift might be pulling it out as well is your adjustable
Alan_Vander
Alan_Vander
1,547
2,751
rosepine,la
if your running anything other than stock shocks you need to run limiting straps. i i cant give you the measurement right now. but if you get the measurement from a stock honda shock. fully extended
this should help you from popping axles. 5 yrs on 27 executioners on 2.5 strongmade lift. stock axles still. and i do alot of off camber and 4 lock full steering lock
scott
scott
1,212
1,354
lyman, South Carolina
I haven’t had any issues since I swapped to the Commander shocks. I keep the shocks on the lowest setting about 2” of lift. 3 years now. No limit straps. I ride pretty hard too.
Alan_Vander
Alan_Vander
1,547
2,751
rosepine,la
whats your full drop look like?
Alan_Vander
Alan_Vander
1,547
2,751
rosepine,la
Finished up the Commander swap for my 700-2 and my front axles bind at full droop. Searching for the simplest/cheapest fix... Axles, straps, etc...?
chain
Alan_Vander
Alan_Vander
1,547
2,751
rosepine,la
sorry i just woke up lol. you can use chain that works for the bolt holes and on the ends of the shock to find out where you dont bind at then measure and buy the straps or just run the chain on the shock bolts. they make limiter straps but they sale them by the lengths
Alan_Vander
Alan_Vander
1,547
2,751
rosepine,la
or if you have the stock shocks handy fully extended go 1.25-1.5 inches longer at the bolt holes. and you should be good. i have 5 inches of lift on stock shocks and my axles dont bind. but im only about 1.25-1.5 inches past full drop of stock shock cause the strongmade shock lift. full droop my axles dont bind and i have stock axles all the way around on my 2014
Reactions: KyleC and Backwoods
KyleC
KyleC
102
155
Pittsburgh, PA
Okay. I'm running the Commander conversion, which puts it at about 2" of lift, but the commander shocks definitely extend much more than the stocks at full droop. And, after a little inspection today, I noticed the passenger front has a split boot... May just take the opportunity to upgrade to Rhinos, and not worry about it any longer!
TonyRad
TonyRad
6
5
Louisiana
Anyone have issues with front axles on. 700-4 I have a three inch lift and outlaw2 seems axles are o er extending and coming apart. Am I the only one?
i snapped one of my front axles with a 2.5" lift n 25" tires, put rhino axles all around n no problems. i wanted the 2.0 rhinos but they don't make it for our 700's
Alan_Vander
Alan_Vander
1,547
2,751
rosepine,la
this is what i was worried about with people running this converison. 3 wheel equals too much. a chain limiter is a cheap upgrade.
scott
scott
1,212
1,354
I haven’t broken any axles on mine it’s a 14 so I’ve had it awhile. I did the commander shock swap so about 2.5” lift. lol just looked back over this and realized I responded awhile back lol
Cyberjunk
Cyberjunk
Berserker
1,622
6,078
Crane Hill Alabama
Well have broken severial with the can am shocks. But it was with dif lock and turned and the last was due to a folded tie rod so......and all of them while driving my grand mother to church on gravel roads !
Cyberjunk
Cyberjunk
Berserker
1,622
6,078
Crane Hill Alabama
Well have the same and have broke several. but with dif lock and turning. And the last was with a folded tie rod so that dont count kinda.
