P500 Accessory Brackets Needed
Murpheeslaw
5
Cumming, Georgia
What brackets will for the roll cage bars for cube light installs? I have bought several mounting kits for my cube lights to mount on the roll cage. None of them have fit very well and they move around. I need them tight!!! Any brands or ideas are appreciated.
Reactions: Russ989
Russ989
Russ989
22,519
146,075
Depending on where you want them, you might consider the Honda quick clamps.
Reactions: Mudder
Mudder
Mudder
NTC Ambassador of Walls
11,273
83,551
Second the OEM quick clamps if right for your placement. I got them to mount a ham radio. For A P500 the size is 41.3 mm (Approx 1 5/8 in.) There is a larger diameter for the larger Pioneers.
Murpheeslaw
5
Cumming, Georgia
Thanks Mudder. Just got 6 of them on order. Another question what brand/size light bar do you suggest for the 500? Looking to purchase one and I want to make sure it fits between the front roll bars on the first shot. Any help is always appreciated.
Thanks!
Mudder
Mudder
11,273
83,551
No light bar here. But here are some Light bar search results just on the P500 forum, for some light reading, if you haven’t already seen them.
