P700 Accessory Sub Harness
William
William
1,442
2,887
Flowood MS
Looking back at this, I do not recommend this anymore! Get the correct harness...
918DF520 A32C 476C B30A AB500D7A0C3F 082580A0 F22F 4C10 A485 7AC02ACEB578
P
Pilot2016
118
173
Rockhill Sc
I purchased this sub harness off EBay to provide 4 keyed circuits for accessories.
Part number HONDA 08Z08-HL5–A00.
It’s a P500 harness but someone said (maybe you) it works on my 2018 P700-4.
Is this the location in the hood (pic below) where it plugs in.? If so, I assume there’s a way to open up this plug so it will insert???
I’m a rookie at electrics😩😩
Note: I did install the Rear LEDS from the HONDASXS STORE. That was so nice to truly plug and play!!!! My kind of accessories!!!😀😀 Richard had to even help me with that.THX to him. They are GREAT!!
now back to this harness......
will it work???
Image Image
Mudwing
Mudwing
36,959
306,672
The Mud holes
will it work???
View attachment 181924 View attachment 181925
The sub harness plugs into the back of the 12V outlet. And then the plug that went into the outlet goes into the sub harness. You access from under the hood. 😉
Reactions: Backwoods
P
Pilot2016
118
173
Rockhill Sc
Thx Mudwing:
I have the harness you’re talking about that I bought from the HondaSXS store. It does go inline from 12v plug. It give a single key controlled wire. (Guess I might could split this by wiring a small 4 position bus bar to run 4 relays for the accessories????)
The one I’m talking about (see pic and part number)is supposed to provide 4.
Here’s another pic of the 4 way harness and I hoped it plugged into the red plug you see behind it???
Thx for reply.
79055D8D 7B87 458C B7A0 FA2810A8F2F1 AA22E9B7 C76B 4E5E 9B5D 8008CA138427
Mudwing
Mudwing
36,959
306,672
The Mud holes
Thx Mudwing:
Thx for reply.
View attachment 181949 View attachment 181951
I think that red plug with the cap is a data link connection point. 🤨
P
Pilot2016
118
173
Rockhill Sc
OK .. it’s a data plug😫Thx again!!!
WILLIAM started this thread and said he installed the harness I’m talking about on a P700. (It’s a P500 harness)
I was hoping he may better describe how he did that. I can’t figure out his picture above that showed the connection.
Did you tap a wire??? Or is there another connector that I need to look for???
Reactions: Mudwing
Mudwing
Mudwing
36,959
306,672
The Mud holes
@William can you give this man a hand? 😉
William
William
1,442
2,887
Flowood MS
Mudwing
Mudwing
36,959
306,672
The Mud holes
Good morning. Yes the plug I went into is a data plug, but works great for accessories. They could unplug it if needed and use it. Just pull the cap off the red plug in the picture and plug the harness in. There is a collar on the plug you may have to remove to make it snap together. I can’t remember that part. It has to snap together or you won’t get power.
Good call. I didn’t know you could tap into that. 😉
P
Pilot2016
118
173
Rockhill Sc
William:
Thank You
Been busy off line and did not see your post, or the other responses. Thanks to all.
I'll be getting back to work on it tomorrow.
Reactions: Mudwing
P
Pilot2016
118
173
Rockhill Sc
@William or anyone:
Back to trying to install that 4 lead harness to get switched power (x4) on my 2018 P700-4.
First of all, I can't even get the red plug unplugged on the ”data plug”. 😩😩Does it require something besides a screw driver?? I can't seem to be able to get it to release by moving the tab.
I'm holding both red plugs that need hooking up together. The data plug has 4 wires (cylinders). The 4 lead harness only has 2 pins. They would seem to line up with the Green and the red/white cylinders in the data plug.
One of these pics show a BLACK HARNESS (same type plug as the red one) next to the red data harness. It only has 2 wires in it. Could that be the one I need to hook up???? Or does anyone know what it's for???
I'm confused as usual.
Getting the data plug UNPLUGGED is 1st priority. I'm afraid to pull on it too hard because I don't see the locking tab moving far enough to release the 4 cylinders🙃🙃
HELP
764B4051 F84B 4C21 9F42 228583AB76DC 794D7E08 DB08 4901 BFC0 27DD7C922F0F C428EA67 ADC2 4439 A06B C21BCD8DD298 86050169 FA20 4EAC AE6C 335BC35FC020 E4053191 3B3E 4BBC AE83 546CC797B3C1
William
William
1,442
2,887
Flowood MS
If you are going to hook up a lot of accessories I wouldn’t use this. I only needed one hot wire. I didn’t even use a ground on the harness. Looking at your picture, I don’t think there is even a ground in that plug. My advice is to get an expert to look at it. I would hate for something to go wrong with this.
Reactions: Mudwing
67,230
To get the plug apart. You just lift up this tab and pull.
Get a pare of needle nose and pull the 4 round cylinders and wiggle it out while lifting the tab. Dont pull the wires.
Abf055e64c127a913cd160ce73ccee14
QuadMan747
QuadMan747
344
566
Connecticut
www.cccmx.com
  2. Other Brand
Years ago (mines a 2014) I bought one (inline plug) from Honda for my 700 and it had 3 or 4 leads and a ground, I have my winch on 1, front and rear lights on another. (3 keyed power wires to respective solenoids, main power from battery for all)
Seems like I have an extra wire, I better add something ;-)
Reactions: Mudwing and William
William
William
1,442
2,887
Flowood MS
Get this harness!
William
William
1,442
2,887
Flowood MS
@QuadMan747 maybe you know?
K
KillYourTV
7
Syracuse NY
I think the one I just ordered only has ground when you go in reverse.
Honda OEM Part 08Z02-HL3-A00
BHarris8753
BHarris8753
78
86
Robbins, NC
I just installed this part number on my 2018 700-2 and it plugs right up under the hood to the red capped off plug, it event hooks back to the support that held the original red cap. with key on it has 4 12v at all 4 wires, not sure about in reverse. I used it to have key on power to my custom switch panel, worked great.
