P1000 Accessory wire size
Hondoman
Hondoman
727
1,697
Texas
What size wire is everyone using? Not sure what all I will add, probably a radio, some led lights, maybe light bar & amp. My initial thought was to use 14 ga throughout. Any suggestions?
I would like to standardize on the wire size and connectors if possible.
Deluxe700
Deluxe700
856
1,101
Central Arkansas
It's going to be hard to standardize due to different accessories having different power requirements. You will have to adjust the wire size and Fuse requirements depending on what power each accessory draws. Some Lights, and the Amp you mention will take a heavier wire gauge. Most accessories will tell you what their requirements for are for that accessory...
Reactions: joeymt33
Hondoman
Hondoman
727
1,697
Texas
Yeah, I was afraid of that. I was thinking I could buy 100 foot rolls of #14 that would work for most things, then purchase larger wire for things that have a higher current draw.
Will #14 work for small lights, 12v ports, etc. ?
Deluxe700
Deluxe700
856
1,101
Central Arkansas
It should those type things...just check the accessory requirements for the accessory....if you go too small, you will REALLY regret it...
and don't forget the fuse..
Hondoman
Hondoman
727
1,697
Texas
Thanks, will do. For now, I just want to add a usb and 12v port. I want to buy the wire and connectors now for future additions which will have to come in January after hunting season.
113,742
I bought 100' of 12ga black lamp cord for all my accessories. The rubber is very thick and has ben super durable. The copper is stranded and is very easy to work with. The cord is also flimsy enough so you can work with it and get it in some tight spaces.
