P500 Adding auto-mode 17 up ECM
dpnorth
dpnorth
North adventures south
159
408
Crawfordville FL
www.youtube.com
  2. Other Brand
  3. Talon X
Anybody out there added auto-mode to their 15-16 P500? I searched around a bit and couldn’t find any posts.
I have mine for sale due to too many toys, and I am on the fence about keeping it or not.... if it was a 17 up, I would keep it. Rather sell the wife’s Prowler 500 than the Honda, but that lack of auto annoys her around the yard doing work.
Maybe I just trade them both in on a new P500, and swap my bolt-ons over.... but if a switch and an ECM is all I need to add/swap, might be cheaper to go that route.
Thoughts?
Reactions: Mudder
HondaTech
I thought some had done so with the newer ecm and a switch, since all it's doing is grounding the "auto" wire in the ecm. I don't believe the member that did it, used their own switch. You could purchase the Honda switch to make it cleaner.
Reactions: Mudder
nctrailboss
nctrailboss
440
1,454
north carolina
I did the reverse,I got rid of the auto function all together on my 17 model.It will at least take the 17 model ecm,speedometer pod,and one of these SpeedoDRD.Don't know if the 15-16 wiring harness will support the upgrade.
Reactions: Mudder
dpnorth
dpnorth
159
408
Crawfordville FL
www.youtube.com
  2. Other Brand
  3. Talon X
thats a start! did the 17 up harness plug into the 15-16 ECM? i can most likely figure it out if the plug is the same. I have a speedoDRD already. speedo doesnt right right anyway after 906UP gear increase.
Why a new instrument cluster? (most likely to display the AT/MT modes id wager.)
Reactions: Mudder
HondaTech
You wouldn't need the harness I wouldn't think.
Should just be able to locate the pin on the ECM for the auto switch and pin it yourself to a switch that grounds out when "auto" is engaged.
Reactions: Mudder
nctrailboss
nctrailboss
440
1,454
north carolina
You are correct,the "auto pin" can be located and grounded by switch to engage auto.For what ever reason,there are different signals sent to the speedo pod on the different years.Change the ecm,and you have to change the pod to match.The module and pod both use the same plugs for the different years,So,use a 17 speedo pod,ecm,find the pin on the module that grounds to engage auto mode and ground it through a toggle switch,and set your SpeedoDRD to read 40mph wide open in 5th would do it.I don't remember the pin # that has to be grounded for auto,but it is easy to find by looking at the 17' wiring diagram.
nctrailboss
nctrailboss
440
1,454
north carolina
Can
'There are some different signals sent on different wires with the ECM change.I had to change to make it work.I started with the ECM change,then discovered the pod had to change,then had to add the SpeedoDRD to finally tune it all in.Works as it should now.I changed because I did not like the auto downshift.
Reactions: Mudder
