F
In my pointy head, it should work. Vacuum is vacuum, but you may want to continue to check throughout the first filter life, taking note of vacuum at various dirt loads of the filter. We don't know how much vacuum the filter will stand before it fails. Experience says the filter is cheap. Lost a 5.9 cummins to sand when it sucked the filter between services. Keep us updated.I have the Gauge Wix part number 24801 Paper work and instructions inside list the Mfg as
Engineered Products Company Waterloo Ia 800-689-7803.
If it works like I think it should, I would easily know when to clean my air filter because it shows restrictive as opposed to looking at it and thinking it is dirty and restrictive. When the OEM green filters look plugged they could actually be passing air just fine. I use a R2C filter on my talon.
A couple of points -I'm going to keep watch on how it performs with my talon. Hopefully it will allow a owner to get the most out of the air filter,,,especially with the OEM one,,,, and know when to clean or change the after market filter. My understanding is that when a filter gets dirty it goes thru a stage where it does a better job of cleaning the air until the restriction comes in to play effecting performance.
The weather is dryer and roads are much more dusty no better way to put it to the test. I will keep a close watch on the inside of the intake tubes, if any dirt is going thru it will show up on the inside of the tubes. The deal breaker is when the tubes show dirt and the filter minder shows the filter is still good,,,only time will tell. LOL
To be continued.....
Yup, my thoughts exactly! I'm glad it stopped all that stuff but the " inside the airbox" set up is not a viable solution. I need to get the pre-filter outside the body at a minimum, either with the @hondabob version or a particle separator kit.Ewwww …
I wonder how the particle separator compares to the external Uni? The separator had to be invented for a reason, maybe a higher dirt capacity.Yup, my thoughts exactly! I'm glad it stopped all that stuff but the " inside the airbox" set up is not a viable solution. I need to get the pre-filter outside the body at a minimum, either with the @hondabob version or a particle separator kit.
The Talon only uses the narrow band O2 sensor fuel feedback idle and low cruise. The Talon does NOT have a Mass Air Flow Sensor so it has absolutely no idea how much air it is taking in so for everything else, it uses Alpha-N and Speed Density modes with tables and sensor inputs to control the injector pulse width, timing, etc. Basically it runs in open loop as soon as you stomp the pedal.3. Someone else said their fuel mileage went to crap when their filter got too dirty, this one may or may not be true - with FI, as the filter gets dirty, it 'should' lean out the mixture not richen up which is caused by the high vacuum caused by a dirty filter. I don't have a clue. 🤔
I can confirm that the S&B works as good as or better than advertised. This is my filter after ~1500 miles with the S&B and lots of dust and a couple of sand storms at the dunes, it looks brand new and the inside of my air box and inlet hose are pretty clean (just a tiny amount of heavier dust at the bottom). I truly believe my filter will last at least 10,000 miles. Divide that by 300 miles that I was getting out of the stock setup and I will save 33 air filters. That equates to $1300 and a lot of trouble saved. The S&B is WELL worth the money, it saves you money in the long run...I wonder how the particle separator compares to the external Uni? The separator had to be invented for a reason, maybe a higher dirt capacity.
Yes, the S&B uses a fan and makes a little noise. I didn't use the Honda one (bought one that fits a CanAm) so I could mount mine on the roof so I didn't have to hear it. Also relayed it so it only comes on after the engine starts. Works perfect for me but I don't do a lot of trail riding with low branches. I am considering getting a full aluminum roof and moving it down back and under the roof line (it interferes with my Rugged Radio a little bit). I will most likely put in a rear window to keep the noise down from the S&B AND the engine. I put a full windshield in and the engine noise is now a lot louder in the cab.@PaulF Do you have a photo of the S&B? I'm familiar with the separator that mounts behind the passenger's head and is unpowered (I don't remember the MFR). Does the S&B use a fan?
You will not be disappointed with the S&B. My air box and filter looked like yours on my first filter change too. The S&B all but eliminates that "mess". For me it has worked on everything from the most fine (almost talcum powder) dust to a sand storm and kept my filter like new for over 1500 miles and I am often in the back of the pack because I have a radio.Great discussion and thanks to you guys for the background info on filters. I installed the S&B a month ago and am waiting to see how it works for me.
My thoughts are that a pre=filter installed Inside the airbox adds some potential issues.
How do you know that the pre-filter is dirty without opening up fairly often.? Doing so adds the risk of inadvertently leaving a leak in the gasket if not seated perfectly. Why does Honda OEM Filter come with both gasket "o-rings" with each new filter? Is it because of the potential for a less than perfect seal by re-using one that has only 30 to 500 miles on it ? I see it like replacing the crush washer on the drain plugs each time we do an oil change
Below is a photo of my filter with 750 miles of Utah Canyonlands riding before S&B added. I am usually by my self or the leader so I assume this is all self inflicted /generated dust. I will give the S&B 1000 miles and check the filter and inspect for dust on the "clean" side. We have all read the experience of others with engine damage due to only a small amount of dust getting through.
I see it as one of several design flaws on an otherwise great machine. As I am new to the SxS world, still preferring my Quads and Mountain Bike, I'm finding this is a very expensive sport. But I still love my Talon.
View attachment 206823 View attachment 206824 View attachment 206825
I can't divulge that information, it is a trade secretPaul, This is interesting. How do you get the "engine on" signal to trigger the relay ? I'd like to do that to mine, as i am using "key on" power now.
