So, I have read through most of the threads on the dual battery setups, lots of good info.
I want to run a battery under the drivers seat probably going to be a optima D34M blue top.
I'm planning on using a true battery isolator.
The stator output looks to be 600w @ 13ish volts, minus 50 watts for running power, that's right around 40a.
But,the wires running to the battery look like 10-12ga, putting the charging amps at 25-30.
My question is what gauge wires should I run to my battery under the seat?
Looking at some charts it looks like all I need is a 10ga wire.
