O
I understand tapping sources for key on power, lights on power, and reverse power. My question is using multiple switches/triggers for a single accessory.
Put more simply, do I wire each accessory then add as many triggers to corresponding input to the Bussman PDM as I want with all of the triggers tied together?
The reverse lights are the most complicated scenario. Most of the time I want all accessories to have key on power but I also want a bypass switch to power on all accessories with key off if desired. Do I just combine the output of a switch wired directly to the aux battery and the Key on power before the PDM so both activate it? I want reverse lights to come on automatically in reverse so I would combine the reverse trigger wire with the output wire from the switch panel back to the PDM so power is supplied if either event occurs?
