P1000 any new warn axon installs?
L
laudy
United States
have the pioneer 1000-5 and still considering the new warn axon 45 with the warn 93790 mount plate on the factory bumper setup. to those of you with this same setup. how did it go together?, any grinding or cutting? how is the angle of pull ? some photos would be great.
Thanks in advance for you time.
Pilotadam
Pilotadam
326
735
Pell City, Alabama
I installed a axon55s on my pioneer, but installed it on a Tough Country bumper. Was super easy to install. I did make my own cables out of 4 gauge instead of the 6 they came with. It took me way longer to mount my full size battery under the driver seat then installing the winch. 36e9fc9541e19d96460630284166c397
Reactions: TripleB
sharp
sharp
3,757
14,955
Tennessee
A little grinding on the bash plate. It's kinda confusing because the winch is mounted upside down. Other than that its easy. The pull is from the "top", which is actually the bottom of the winch. I have pictures on my phone. PM me and I'll give you my number incase you have any questions.
Pilotadam
Pilotadam
326
735
Pell City, Alabama
I wanted a 2nd battery so I wouldn't drain the main battery to the point to cause clutch problems. From reading lots of post if the main battery is low the Pioneer I will not perform properly.
I went full size because the cost was not much different than a good power sport battery, but gave me a lot more capacity. That way if we stop on the trials I can leave lights and radio playing and not worry about a dead battery. (Note I had this happen on my Teryx with a single battery)
I upgrades the cables to reduce the heat and loss when the winch is pulling a lot of Amps. There web site says 254 Amps max for the 55S I installed. Which if you look up sizing that would require a ~2/0. So if figured the biggest I could fit the better. My teryx had the wiring that came with the unit ran alot further and I never had a problem. I just had the bigger cable left from another project and figured it would help.
I used the 2 gauge to ran the leads from the full size. Battery up under the hood again for capacity and run length. You get much bigger and the cost and difficulty to run it goes way up.
The picture is under my hood. I am still working on wiring but it gives you an idea of what I am doing. In the top left bolted to the cross bars you will see where the battery terminals come in and connect with the winch and the rest of my accessory wiring.0b134391a2e34cf98429ddcbc35ac8c06b5560e3344e42989e91ac13d68aeed2
Reactions: sharp
Rottiedog
27
37
Boulder, CO
Sorry, i’m A newbie and do not know (yet) how to PM.. I would be interested inn knowing more about the install and what needed grinding. Thanks
Reactions: JSDAVIS
obas
obas
11
31
Pell City, AL
Pic taken from the drivers side showing the notch needed to fit the Warn Axon 45
Winch Grind
Reactions: JSDAVIS
Rottiedog
27
37
Boulder, CO
I installed a axon55s on my pioneer, but installed it on a Tough Country bumper. Was super easy to install. I did make my own cables out of 4 gauge instead of the 6 they came with. It took me way longer to mount my full size battery under the driver seat then installing the winch. View attachment 165718
Do you have any pictures of the battery mount? Thanks
Rottiedog
27
37
Boulder, CO
The picture is under my hood. I am still working on wiring but it gives you an idea of what I am doing. In the top left bolted to the cross bars you will see where the battery terminals come in and connect with the winch and the rest of my accessory wiring.View attachment 166210View attachment 166211
Hello, very interesting installation. How does the second battery, under the seat, get charged with your installation? Could you sketch of the wiring? Thanks
Pilotadam
Pilotadam
326
735
Pell City, Alabama
i purchased a Alumn Machined Battery mount of ebay and then used a thin sheet of metal and metal brkts to bolt it in.
For the wiring I used a Ture Isolator. i purchased some battery studs of Amazon and ran my wiring to that. Sorry the wiring picture is kind of a mess. When i get a chance i will put a rough diagram on paper. 3e1d19b90f135f24957b70190478e09c3d5d5c024b2468de52f135d22ae3e085Ae98d69e7142bfb7f474f48f7a24fe4758cf55efed3add33bf1cf41628921c67D79be479e991c21f9deaf9cdcdc43c89
Rottiedog
27
37
Boulder, CO
For the wiring I used a Ture Isolator. i purchased some battery studs of Amazon and ran my wiring to that. Sorry the wiring picture is kind of a mess. When i get a chance i will put a rough diagram on paper. View attachment 228812View attachment 228813View attachment 228814View attachment 228815View attachment 228816
Thanks for the pictures. If you can post a diagram I would like to see it.
Thanks for the pictures. How do the second battery get charged? Is it because of the isolator? I’d like to see a sketch if possible to understand where in the circuit the breaker was positioned and how you chose what ampersand you did. Thanks
Pilotadam
Pilotadam
326
735
Pell City, Alabama
Hopefully this sketch is clear. The 2nd Battery charges thru the Isolator. once the stock battery is charged, but it keeps the accessories from pulling power from the stock battery. If you have any other questions let me know .2db63b7051aa795450009eb2694b0c79
Rottiedog
27
37
Boulder, CO
Hopefully this sketch is clear. The 2nd Battery charges thru the Isolator. once the stock battery is charged, but it keeps the accessories from pulling power from the stock battery. If you have any other questions let me know .View attachment 228830
great, made it very clear. Thanks so much for your time.
Pilotadam
Pilotadam
326
735
Pell City, Alabama
No problem. If you have any other questions let me know. I spent way to much on wiring.
G
goheelzfan
11
10
NC
I mounted mine without cutting any part of the frame. Mounting the winch was a breeze compared to the mounting the switch in the dash. That was tedious.
JSDAVIS
JSDAVIS
17
27
NC
Can you post a picture of the side view where you didn’t have to cut anything please?
