P1000 Axle build list & How-To
39,079
I was ordering spare axles to keep around incase I ride with @Eltobgi again! I though this would be a good time to share the part numbers with you guys because its easy to forget a small snap ring.
It is my experience that tells me that you can swap the two front axles as they are they same even though they have different part numbers. the two rear axles however will not swap and they are not a swap for the front. also of the parts are interchangeable but not the complete axle. also, the front inboard CVs are not the same as the rear inboard CVs. the rear set is shorter.
I am currently carrying one spare axle for the front that will work for both sides. currently I only have spent the money on one rear axle but will probably soon order another which will be the last one. I keep these in my truck when riding so they are at least close.
39,079
Here are the part numbers I retrieved from RMATV I also used their prices.
Right Rear:
Shaft Set: 42250-HL4-A01 $180
Inboard joint: 42220-HL4-A01 $120
Snap ring: 42228-HL4-A01 $2
Inboard boot set: 42260-HL4-A01 $40
Kilo427
Kilo427
1,543
6,439
39,079
Left Rear:
Shaft Set: 42350-HL4-A01 $180
Inboard joint: 42320-HL4-A01 $120
39,079
Front Right:
Shaft Set: 44250-HL4-A01 $180
Inboard joint: 44220-HL4-A01 $120
Inboard boot set: 44260-HL4-A01 $40
39,079
Front Left:
Shaft Set: 44350-HL4-A01 $180
hopefully I didn't type anything wrong. please check the part numbers before ordering!! my typing isn't that great....I live in Alabama which is just one level above Tennessee!
39,079
One more note, you guys may be thinking why order the "boot set". well, it comes with the grease, boot, bands, circlip, and snap ring. still over priced but you'd have to source these parts individually if you purchased the "all balls" boot.
Reactions: knuckledeep
39,079
Here's a picture of a front inboard joint next to a rear inboard joint
0e293e5658b16f3af7992b5a6198982e
nbomar
nbomar
4,416
17,854
Springdale, AR
Can you not buy a complete axle already built? I was planning on looking for these in the somewhat near future. Thanks for the research.
39,079
I have not found axles complete and ready to go yet. I assume that the aftermarket will show up soon with some. I hope they do because the OEM is expensive.
Eltobgi
Eltobgi
4,599
15,186
North Dakota
Trying to get by as cheap as possible! Lol. Not a bad price compared to Pure Honda where they were quoting $240 plus tax!
IMG 0741
Reactions: JTW
Eltobgi
Eltobgi
4,599
15,186
North Dakota
Axles are about $20 less than that from Babbits
Now you tell me:confused: Thanks for the heads up! Do they offer free shipping?
Reactions: JTW
