P1000 Back doors rubbing on Hard door frame
primeau
primeau
68
25
North Bay, Ontario, Canada
I'm having a small issue with my back door(driver's side). It is rubbing when I open it on the metal frame of the front door(hard front doors). I brought it to the dealership and they said they've never seen that before. The Honda Rep was there and he said the same thing. Has anyone had this issue? Is there some specific bolts I need to loosen and move something over? The other side btw is close to rubbing but fits very nicely I find. Thanks for any help. The dealership would look at it but everything they will try is just guess work, so I might as well and try myself.
https://www.facebook.com/photo.php?fbid=10156571838110675&set=pcb.1848107565302671&type=3&ifg=1
41697966 10156571838120675 1504768090238353408 n 41810115 10156571838130675 430144303294054400 n
Reactions: BWAF
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
Can you loosen the bolts in the hard frame and slide it forward any? If not you may need to slot those holes a bit to make clearance.
Reactions: BWAF
