P500 Backlash/slack noises from driveline
Richd
Richd
24
47
Vallejo,CA
My 2017 P500 has always been a little noisy when cruising under no-load (neither on or off the throttle) situations. Lately it seems worse but still drives normal when on or off the gas. I would describe the noise as similar to a loose/worn Ujoint on a driveshaft. It is worse in 2WD but is present also in 4WD.
I thought I'd put this post in to see if others may have experienced the same noise. I mostly use the machine as a workhorse hauling yard debris and leaves with a small trailer to the burn pile about a 1/2 mile from my cabin. I have ~350 miles on it so far. Some low speed sight seeing on mountain roads and trails. No flat-out racing at all.
Rich
Reactions: rtn001
G
Gassygordo
302
1,025
Fillmore, NY
Rich
I have a 17 with nearly 1900 miles. I get a lot of weird noises in the drive lines, but keeps on truckin. I just figure if something shows a lot of ware or breaks, I'll just fix it.
182,037
Rich
Yeah they all do that. There is someone on here that makes a noise/heat barrier that helps with that. ;)
SpaceTroll
SpaceTroll
141
540
Kirbyville Tx
I have a definite pop noise when going from forward to reverse and also from reverse to forward . I noticed awhile back I had a torn boot on the rear drive shaft. When I replace it I'll check the u joint to see what shape its in and will probable replace it while I'm there. I'm well over 3000 miles on the machine
Reactions: Ollie and rtn001
ShotgunClay
ShotgunClay
172
594
Founders Ranch New Mexico
Same here with my 2017. It was louder when I first got it, but has diminished. Now have 2600 miles. When I changed the differential oil to a heavier type, everything inside looked shiny and smooth.
I think it's just the nature of the beast.
Reactions: rtn001
jamesh
jamesh
253
350
DFW
These machines sound fine under acceleration. Super noisy when coasting or decelerating. Coffee can full of nuts and bots. Add to that, the rear brakes on one of mine squeak at low speeds, especially after going through some (not deep) water. Can't wait till next year when I replace one with a Talon (or maybe a [GASP!] RZR).
Rustneversleeps
Rustneversleeps
302
582
Talon,New Brunswick,Canada
Mine does it to and it sounds like the gears to me "Big Clunk" and every time it does a cruse and swear and say WTF...
Also i find it does it more in Auto when you are starting to stop and the gears do there stuff going from 5th down to 1st from 2nd to down to 1st that when i hear it....
I don't hear it much in Manual i guess cause we're changing the gears when we come to a stop..
Reactions: rtn001
DWBourque
Louisiana
I hear clunks and noisy clinking down shifting in automatic. Happy to hear I am not the only one to hear this.
Reactions: rtn001
Mudder
Mudder
NTC Ambassador of Walls
11,690
88,472
Recall an old post about the way the gears are cut. Hypoid cut??? Guess most do hypoid rated synthetic oil + rubber trigger shield and then either ear plugs or crank up the music.
Bastardchild
Bastardchild
1,978
7,251
Orange Heights, fl
Mine was making a clunking noise about 5 months ago or so when I dropped it into gear from neutral. In my mind, what I thought was happening was rear diff gears were making noise because of bad bearings or something. Tore rear end apart to replace gears but everything was tight. Put it all back together and made it repeat the noise. Come to find out my clutch needed adjusting. When I would drop it in gear I guess the internal clutch parts rotated about 1/4 revolution before it engaged the driveshafts to turn the diffs. When the internal rotating parts caught up to where the drive shaft was sitting still it gave the 'clunk' sound. I looked up how to adjust the clutch and it has been good to go since.
Rustneversleeps
Rustneversleeps
302
582
I'll guess I'll check my clutch again and fine tune it..
Richd
Richd
24
47
Vallejo,CA
I adjusted the clutch and the backlash noise went away. That was good.
On a test ride however when climbing a hill I went to shift down and the engine would cut out for a second...but no downshift. The display then went to a "dash or hyphen" where the gear position is displayed.
The proper adjustment is one quarter turn counter-clockwise from the full seated clockwise position on the adjusting screw, then tighten the locknut while holding the screw from turning....correct?
Still I'm happy to have the noise gone...maybe the speed sensor got affected?
Mudder
Mudder
11,690
88,472
1/4 to 1/3 turn, played around for the sweet spot.
Reactions: trigger
Rustneversleeps
Rustneversleeps
302
582
i might try the 1/3 turn did mine at 1/4 turn seem to be ok most of the timed,It's the down shift parts where it sounds like it needs ajusting. Should the screw be snug or just when your about to feel Resistance and 1/3 back then tighten.
