L
Mine constantly kicks out! Any ideas? Anything other than flat surface it kicks out!
So just run straight wire to the battery and call it good?Always tossed them on superwinch installs.
I've got a new ramsey winch that I haven't installed yet be the instruction say to wire it directly to the battery. Hot and ground.
Good luck. If you get mired bad and need full power out of that winch you’ll be doing plenty of regrouping.I installed my breakers not a problem yet i have used it a lot.BUT not a hard pull.If i see a major problem as others have stated i will rewire i kinda like only spiking the battery at 100 amps it gives you a chance to regroup.
