P700 Badlands winch mount ???
V
Von
23
26
North east TX
I had read that you had to deform (w/heat gun) the headlight housing for a highlifter kit THATS no BS had a hard time with the front!! the rear easy 30min! I have ground clearance now!! winch mount went easy but rain storm hit couldn't dress up the wiring (no pic) still need to install dash switch/remote plug
IMG 20200515 165432399 HDR
Reactions: Mudwing
jakes29
16
26
oklahoma
I had read that you had to deform (w/heat gun) the headlight housing for a highlifter kit THATS no BS had a hard time with the front!! the rear easy 30min! I have ground clearance now!! winch mount went easy but rain storm hit couldn't dress up the wiring (no pic) still need to install dash switch/remote plugView attachment 202660
what winch did you install and where did you end up putting the dash plug?
Reactions: livefromthetree
V
Von
23
26
North east TX
Badlands 5000lbs (was told it is great for the money) seems to work well, I seen where someone had put there remote plug in the middle under my light up front(can use on either side) put other switch in the dash
15923599042585993064271889715289
Reactions: Mudwing
V
Von
23
26
North east TX
Dash switch is left side bought the switch bank off Amazon , gives another power port,battery voltage, usb, and 3 switches, still not complete a work in progress LOL
15923602551916891955885040631620
Reactions: jakes29 and Mudwing
jakes29
16
26
oklahoma
Looks great. I installed the same winch, trying to figure out where to put the switches
jakes29
16
26
oklahoma
Last thing to wire is this socket lead on this badland winch. Manual says it need to be connected to an ignition circuit but the wiring diagram show it’s connected to the solenoid. Any help?
8501D005 B6B7 47A6 8CCC 54A010D4C293 55CEBBCB 9B69 4A89 9874 BCEAF3C2A2FA
V
Von
23
26
North east TX
Thats so it only will work with key on i put mine on a always hot BUT pulled the black & blue wires (I think) off the solenoid to many grandkids climbing in and out of mine if I need the winch (very rarely) pop the hood hookem up for now
Reactions: jakes29
jakes29
16
26
oklahoma
Thank you!! Got her working now(although switch is backwards lol). Trying to figure out how big of a hole I need to drill In the glovebox for the remote
